Old 01-28-08, 12:07 PM   #1 (permalink)
Bill D
I Have No Life
Rep Power: 32 Bill D has much to be proud ofBill D has much to be proud of
Epoxy Adhesive Question
My aluminum mono tub is powdercoated. I want to epoxy on 4x9 fuel filler plates onto the sills to give the illusion of an original mono tub. Do I need to remove the powdercoating where the adhesive will go?
Bill D
Bill D
RCR GT40 Mk1 Gulf
Bill D is offline
Old 01-28-08, 12:21 PM   #2 (permalink)
Big-Foot's Avatar
Big-Foot
Gold Supporter
GT40: Replica
Rep Power: 18 Big-Foot has a brilliant futureBig-Foot has a brilliant futureBig-Foot has a brilliant future
Re: Epoxy Adhesive Question
Bill D
I would think you'd be fine by just roughening up the PC where you want the epoxy to stick.
Regards - Randy
Big-Foot is offline
Old 01-28-08, 12:26 PM   #3 (permalink)
GT40: New York
My two cents:
1. Call the powdercoater and ask his opinion;
2. Call the epoxy manufacturer and ask his opinion.
Epoxy's generally do not generate much heat when they cure, but I do not know what product you are using.
I have always found the BEST advice is to go to the source i.e the manufacturer regarding their product etc.
I would trust the epoxy manufacturer's advice over the powdercoater's advice.
Gregg is offline
Old 01-28-08, 12:41 PM   #4 (permalink)
Bill D
I Have No Life
I'm using JB Weld. I just got off the phone with them and they said all I have to do is rough up the powdercaoting and it will work.
Thanks guys.
Bill D
RCR GT40 Mk1 Gulf
Bill D is offline
Old 01-28-08, 02:05 PM   #5 (permalink)
David Morton's Avatar
David Morton
GT40: The Jewel on the Thames: Marlow, Bucks
Rep Power: 34 David Morton has a brilliant futureDavid Morton has a brilliant futureDavid Morton has a brilliant future
Instead, try using Riv nuts - if you can.
David Morton is offline
Old 01-28-08, 02:16 PM   #6 (permalink)
Bill D
I Have No Life
Dave
I would like to, but it's the fuel tank. Drilling holes would result in a fuel leak
Bill D
RCR GT40 Mk1 Gulf
Bill D is offline
Old 01-28-08, 02:27 PM   #7 (permalink)
GT40: New York
Bill, Is there are reason why you did not epoxy the filler plates prior to powdercoating?
Gregg is offline
Old 01-28-08, 02:52 PM   #8 (permalink)
SpyderMike's Avatar
5 Tenths
GT40: So Cal
Why not VHB adhesive tape? It is a 3M product. We use it to bind items to powdercoated aluminum.
SpyderMike is offline
Old 01-28-08, 03:01 PM   #9 (permalink)
David Morton
In which case as Mike says VHB. Nothing that I've use 3m's VHB on has ever come off again and it holds up some of the signs on the motorways here.
Surely your tank is below the skin on the sill / step area?
Old 01-28-08, 03:13 PM   #10 (permalink)
Bill D
I Have No Life
Gregg-
Because I'm polishing them to contrast with the black powdercoat.
Dave-
The tank is indeed below the skin. No bladder
I will look into the 3M VHB
Bill D
RCR GT40 Mk1 Gulf
Bill D is offline
Old 01-28-08, 03:22 PM   #11 (permalink)
GT40: New York
Bill, that is a good reason.
Gregg is offline
Old 01-28-08, 06:27 PM   #12 (permalink)
Pantera1889's Avatar
Pantera1889
GT40: RCR MK1
I roughed up the powdercoat and used JB weld. Worked like a charm!
RCR GT40 MK1 chassis #14
DeTomaso Pantera #1889
Pantera1889 is offline
Old 01-29-08, 12:22 PM   #13 (permalink)
Mark Charlton's Avatar
Mark Charlton
GT40: GTD #9988
Rep Power: 9 Mark Charlton is a splendid one to behold
I use 3M VHB tape all the time and I suggest it is the right approach. Should you ever decide to re-locate the covers, or remove them for some other reason, the VHB tape an be "snapped" off (using quick prying action) and will likely NOT destroy the powder coating. It will, however stick extremely well. We use it (following correct 3M install procedures) to install metal dimensional lettering onto exterior glazing. Trust me, if it works there (and it does), it will work for you.
The other benefit is that the 3M tape will not have the potential for a sharp bump to break the bond in the way some epoxies can.
Mark
Mark Charlton
____________
GTD40 #09988
71 DeTomaso Pantera
70 DeTomaso Mangusta
Mark Charlton is offline
Old 01-30-08, 10:41 AM   #14 (permalink)
FRPGUY
3 Tenths
GT40: Norwell, Mass. USA
Bill, see if you can get a sign maker to lend a roll to you. A roll of VHB is not cheap! Sign makers that use a lot of plastic use VHB tape.
FRPGUY is offline
Old 01-30-08, 12:35 PM   #15 (permalink)
Mark Charlton
GT40: GTD #9988
True, but it's also available from some commercial auto supply shops since it is also used to apply vehicle badges and trim.
Mark Charlton
____________
GTD40 #09988
71 DeTomaso Pantera
