Old 04-02-08, 11:01 PM   #21 (permalink)
crossle43
GT40: RCR40 #27
Rep Power: 7 crossle43 is on a distinguished road
Re: Lucas mirror ? for Doc Watson
Kim,
Whatever you do, BE PATIENT. If you don't find one this week, don't worry about it, because another one will come along.
Good luck in the search,
T.
Every job is a self-portrait of the person who does it... autograph your work with excellence - unknown
crossle43 is offline
Old 04-03-08, 03:31 AM   #22 (permalink)
Doc Watson's Avatar
Doc Watson
5 Tenths
GT40: Replica Mk I
Here is one.......
JAGUAR MK2 S-TYPE 420 DAIMLER 250 INTERIOR MIRROR LUCAS on eBay, also, Jaguar, Classic Car Parts, Cars, Parts Vehicles (end time 12-Apr-08 11:49:10 BST)
Andy
replica mono chassis
original rear clip
1966 289
48IDA's
This month its going to be red
'This car you have to be measured for...'
Doc Watson is offline
Old 04-03-08, 07:48 AM   #23 (permalink)
steve c
Steve
GT40: SPF GT40 P2125
Rep Power: 6 steve c has a spectacular aura about
Doc (Andy),
I have my mirror apart to the point of removing the old ball and stem.
The ball socket needs to be disassembled in order to install the correct Cushman ball and stem but I'm concerned as the socket assembly plates are held together by 4 small tabs that look fragil and likely to break (work harden and crack) during disassembly/reassembly. Anyone done this and have tips or proceedure?
Also good idea to reassemble with a little neolube or anything in the ball to socket (my as purchased is pretty hard to move and with stub to windshield attachment via adhesive don't want too much force when adjusting mirror position?
To point of attachment to windshield..what have others used or suggest?
One more...Thinking of offsetting the mirror off of centerline in windshield...good idea?
Thanks, Steve
steve c is offline
Old 04-03-08, 12:16 PM   #24 (permalink)
Doc Watson's Avatar
Doc Watson
5 Tenths
GT40: Replica Mk I
Steve,
We have turned full circle on this Steve, you are now the expert on Lucas mirrors as I havent attempted to take the ball out yet, Jays stem will arrive soon.
My current plan will be to use a small butane torch (used for soldering) to heat the top two tabs and then let them cool slowly in air, thus anneling them to make them 'softer' then attempt to bend them back and remove the plate, once the plate is removed, re-anneal the two pins, fit the new ball and bend them back.
I know that there must be a few people here who have already done this so I guess we both wait for them to speak up or you could bite the bullet and go for it..... I will be asking questions if you do it.
Kim, sorry found the Lucas 608 and couldnt resist a bid myself!!!!!!!!
Andy
original rear clip
1966 289
48IDA's
Old 05-04-08, 07:12 PM   #25 (permalink)
kepetersen's Avatar
kepetersen
GT40: SPF Mk I
Rep Power: 2 kepetersen is a jewel in the rough
Andy
Andy:
No worries, I ended up finding another one in the UK; it's presently winging its way to the states. Did you win the bid? I hope one of ours got it!
Kim
Kim Petersen
SPF GT40 P/2192 Mk I w/ Keith Craft Aluminum 427IR
F430 F1 Berlinetta
SPF Mk III w/ Ford 460
MB C55
"I want to die peacefully in my sleep, like my grandfather; not screaming and terrified like his passengers."
kepetersen is offline
Old 06-26-08, 10:19 AM   #26 (permalink)
jodrell47's Avatar
jodrell47
GT40: Tornado
Rep Power: 2 jodrell47 is on a distinguished road
Paul,
Hi, do you have any of these left i'm trying to get one in advanmce of the LMC to mount my mirror but with no luck. If you haven't any, perhaps you could let me know the following dimensions;
Diameter, length of bar before cutting angle, angle of angle - if you know what I mean ! I may be able to get one machined locally to me in Birmingham when I get back from Libya next week.
I understand (from Frank Catt) you want a peek at my front suspension at LMC = no problem
2007 Stroked 347
2008 Extensive mods by Frank Catt
jodrell47 is offline
Old 06-26-08, 02:49 PM   #27 (permalink)
PDub's Avatar
PDub
6 Tenths
GT40: Tornado
Yes got a few left send me a pm and we can sort it out.
Best regards,
P.
Black Tornado TS40 a.k.a. "Black Beauty"
SBF 306 / Edelbrock pack / R21-Turbo box / Quaife LSD
17" BRM Pindrives / Roll cage / Hi-Spec brakes
PDub is offline
Old 06-26-08, 08:57 PM   #28 (permalink)
minerl's Avatar
minerl
GT40: SPF P2133
Rep Power: 5 minerl has a spectacular aura about
After having gone through the entire process of modifying one of the mirrors. It's quite simple really. It just requires a bit of finesse. I would urge you not to use a torch Doc. The tabs can be very carefully worked open on one side and the plate can be "slid" out from under the two on the other side. Once the plate is removed, gently open up the other two tabs just a bit to allow easier reassembly. The mirror I have (courtesy of Steve C) was already worked over once by someone less than careful and I was still successful. Just work the tabs juuuuust enuf to allow the plate to clear on one side.
Lynn
minerl is offline
Old 06-27-08, 12:46 AM   #29 (permalink)
jodrell47's Avatar
jodrell47
GT40: Tornado
Paul,
You have a PM.
John
2007 Stroked 347
