Old 16th August 2008, 06:16 PM   #1 (permalink)
Big-Foot's Avatar
Big-Foot
Super Moderator
GT40: RCR40 - #45
Question Tail Light Mounting - How'd you do it?
Hi Guys,
I think I know how I am going to have to mount these tail lights but I'm not real nutty about the idea... Thought I'd run it past you guys to see how you may have done it or what you suggest.
I think I am going to have to carve a precise hole through the rear body and then sandwich the body between the lens and the plastic housing.. Probably have to RTV the housing to the body in order to make it relatively water tight..
There is a gasket on the lens itself that may seal to the body on the outside..
What are your thoughts?
Thanks..
Regards - Randy
My build site:
Big-Foot is online now
Old 16th August 2008, 08:00 PM   #2 (permalink)
Fran Hall RCR
gt40fran's Avatar
gt40fran
Sponsoring Vendor
GT40: Michigan,USA
Re: Tail Light Mounting - How'd you do it?
Randy,
thats exactly how its done....
RCR-40..Mk1, 2 and Mk4
RCR-70 Mk3b
RCR-70 Spider
RCR-P4
Superlite Coupe
RCR917
XJ13 for SCF
gt40fran is offline
Old 16th August 2008, 08:51 PM   #3 (permalink)
Jeff Hamilton
GT40: RCR
I made the hole the same as the light housing (just behind the lens). There is enough of a lip on the light to keep it from falling in.
Jeff Hamilton
Jeff Hamilton is offline
Old 16th August 2008, 09:31 PM   #4 (permalink)
MReid's Avatar
MReid
4 Tenths
GT40: RCR Mk1
I did the same as Jeff and pushed them in from the back. I then took a piece of flat aluminum stock put two 90 degree bends in it, drilled two holes for the mounting lugs, and slipped it over the tail light housing from the inside. Sort of like how the gauges are mounted. Works great and preserves the seal on the tail light.
[COLOR=black]Have fun with your build! - Mark[/COLOR]
[COLOR=blue][/COLOR]
[COLOR=blue][I]FFR Daytona Coupe[/I][/COLOR]
[COLOR=blue][I]RCR Gt40[/I] [/COLOR][COLOR=blue][I]Mk1[/I][I] in the garage, and underway![/I][/COLOR]
MReid is offline
Old 16th August 2008, 11:04 PM   #5 (permalink)
Rob
VintageVenom's Avatar
VintageVenom
GT40: RCR-40
Randy,
I did is exactly as Mark did. Sized to hole for exact snug fit, then you can secure from the inside like a gauge in the dash.
Rob
aka "VintageVenom"
RCR40 289/webers/ZF
VintageVenom is offline
Old 16th August 2008, 11:16 PM   #6 (permalink)
Big-Foot's Avatar
Big-Foot
Super Moderator
GT40: RCR40 - #45
Thanks guys... I tried the sandwich thing and it didn't work so good... The fiberglass was too thick to use the standard screws and it's too uneven on the backside to seat and seal properly. I think I'll do the gauge thing.. I was looking at glassing in a bracket but that would probably be overkill...
I also mounted the license plate lights and a plate.. The tag lights are not level in the pic as they are not bolted in - just setting in there..
Does everybody cut out the slot behind the license plate?
Regards - Randy
My build site:
Old 17th August 2008, 12:39 AM   #7 (permalink)
Bill D's Avatar
Bill D
I Have No Life
I cut mine open
Bill D is offline
Similar Threads
Early Tail gt40fran RCR Forum - RCR40 /SLC / P4 / MKIV 0 9th September 2007 05:15 PM
Simca tail light bune GT40s Wanted, and Parts or Services Needed 1 6th July 2007 01:27 PM
Tail of the Dragon theon All GT40 3 11th May 2006 07:30 PM
Tail Light Question Bill D GT40 Tech - Exterior, Interior, AC, & Trim 7 22nd January 2005 06:21 PM
Tail Light Lenses llarsen The World Market - Share Parts, Sources, and Reviews 0 5th November 2004 12:26 PM
