Polycarb Windows
Hi Guys
I am just having some polycarb windows made for my car and I would like to put the black edging around then
If anyone has done this could you please let me know what you used :worried:
thanks
Pete
Mark Charlton
When I did my windows and light covers, I masked the windows leaving a 1/2 inch border and sprayed the black using 3M trim paint. It stuck fine and hasn't lifted anywhere in the several years since I applied it.
Keep in mind that you should be painting the INSIDE surface of the plastic and so it will always be protected by being against the body work. You can also paint it with a brush this way and the strokes will not show up. Probably the easiest project one could do on a GT40.
Mark
Thanks for all the answers and info, will have a look and see what I can locate over here
Is there anyone else out there running a big block buick the same as mine in a GT ?
Pete
Buick power - Very interesting! Would like to see more over in the Build Logs section!
