Go Back   GT40s.com > >
Thread Tools Display Modes
Old 5th April 2015, 12:39 PM   #41
dlindemann's Avatar
dlindemann
GT40: Lotus
Re: Electric A/C Compressor
Originally Posted by rockhoppers1964 View Post
Strange that the higher capacity compressor has a lower amp draw? Message sent to manufacturer to confirm.
Dave L
dlindemann is offline   Reply With Quote
Old 5th April 2015, 01:14 PM   #42
Mark IV
I Have No Life
GT40: Superformance
The units (SHM/Jegs) look to be the same, I would venture both are buying them out and putting their labels on the compressors. So what industrial supplier is the real manufacturer?
The GT 40 reunion at the Glen in 1989 was as close to Heaven as I'll get...
Mark IV is offline   Reply With Quote
Old 5th April 2015, 09:47 PM   #43
dlindemann's Avatar
dlindemann
GT40: Lotus
They are definitely the same units. If you look at the Jegs installation instructions they show images of the SHM unit. Reading the SHM site I'd guess they came up with the design but that is a guess. I'll post what I hear from them regarding the amp draw ratings.
Dave L
Old 5th April 2015, 11:05 PM   #44
Howard Jones's Avatar
Howard Jones
Gold Supporter
GT40: GTD
"The AC Compressor must sit in a vertical position, so that there is enough oil in the sump of the compressor for the centrifugal oil pump to lubricate the internals".
From Jegs link install instructions.
My question is, do we think that high G cornering will starve compressor of oil?
Howard Jones is offline   Reply With Quote
Old 6th April 2015, 09:04 AM   #45
wbmusarra's Avatar
wbmusarra
I Have No Life
GT40: DRB#5
Howard,
You must be doing some real "gentleman racing"(cup holders and some Chablis???) if you are taking high G turns with the A/C on!!!!
DRB#5
351W/408 TWM FI. AFR 205s 930 Porsche LSD
wbmusarra is offline   Reply With Quote
Old 6th April 2015, 09:13 AM   #46
Big-Foot's Avatar
Big-Foot
Administrator
GT40: Gulf Cart
I don't know if it's just because I am a cheap SOG or because I'm of German-Dutch heritage but I have to wonder if a 110v Window AC Compressor for a house could be run on an Invertor... No I'm not talking about mounting a window air conditioner in the car, but harvesting the compressor from one and building my own...
These guys are asking for a lot of money on something which is probably available new for less than $100 for an 8,000 BTU unit...
Real Hot-Rodders build their own stuff - maybe I'll use that as an excuse....
Oh and yes, I do know the difference between R12/R22/R134a... But I would bet that compressor doesn't....
Regards - Randy
-- Youth and talent are no match for old age and treachery!
GT40 RCR40 #45 G50-331-Weber IDAs ((Sold))
My build site:
Old 6th April 2015, 08:19 PM   #47
dlindemann's Avatar
dlindemann
GT40: Lotus
Howard - The units so so small that I'd be surprised if a high g corner would cause it to run out of oil but I suppose it is possible.
Randy - How big is that compressor? I agree these units are expensive but they are REALLY small.
I heard from Sean Hyland about the amp ratings. He said the ratings listed are peak at start-up but he didn't answer my question about the lower capacity unit having a higher amp draw at start-up so I sent him another message. More to come....
Dave L
Old 6th April 2015, 08:31 PM   #48
Big-Foot's Avatar
Big-Foot
Administrator
GT40: Gulf Cart
Dave,
I don't have any precise measurements but the unit in one of my son's window units looked like maybe 6" in diameter - max... Maybe 7" tall...
Regards - Randy
My build site:
Old 6th April 2015, 08:50 PM   #49
dlindemann's Avatar
dlindemann
GT40: Lotus
Originally Posted by Big-Foot View Post
Dave,
OK, well that is pretty small too. These units are a little more than 7" tall to the top of the highest fitting and the tank is a little over 4.5" in diameter.
When I think about what it could cost to fit an AC compressor to the engine I'm using with the space I have available, the hoses run through the chassis, etc. the cost of one of these dose not bother me that much.
Dave L
Old 6th April 2015, 10:13 PM   #50
Big-Foot's Avatar
Big-Foot
Administrator
GT40: Gulf Cart
When are you going to put up a build thread on that Europa?
Regards - Randy
My build site:
Old 7th April 2015, 07:41 PM   #51
dlindemann's Avatar
dlindemann
GT40: Lotus
Randy - Someday maybe. I hardly have time to work on the car........
Dave L
Old 7th April 2015, 10:25 PM   #52
Big-Foot's Avatar
Big-Foot
Administrator
GT40: Gulf Cart
I know well how that works Dave....
Watched a couple of YouTubes on the disassembly of compressors like this.
I wonder if one could be modified to use a DC motor?
Regards - Randy
My build site:
Old 8th April 2015, 08:54 AM   #53
dlindemann's Avatar
dlindemann
GT40: Lotus
Randy - It is possible. I know these use a 3 phase motor per Sean Hyland. The amp figures are also accurate with the smaller capacity unit having a higher amp draw on start-up. Rather than spending the time and effort to try and figure out how to make my own I just bit the bullet and bought one of theirs. Saves time and frustration!
Dave L
Old 8th April 2015, 04:45 PM   #54
Howard Jones
Gold Supporter
GT40: GTD
Run the AC on track? Damn right!
I've run my GT40 at Willow Springs when the air temp was 109F and the track surface temp was approaching 150F. At Thunder Hill in the summer air temps are at least 100 and can easily reach 105+. I once taped a thermometer to my dash in my GT40 and got 118F as the car slowed down and ran slowly thru the paddock on my way back to my pit spot. On that occasion I had soaked my T shirt in cold water and put it back on under my fire suit. It was 90% dry in 25 mins. That's not much slower that a clothes drier.
If I could keep the car interior under 90F, better yet 80F, on a really hot day while on track it would be epic! What an improvement in the fun factor that would be. When you are in your 20s, 110F in the car is hot. When you turn 60 it is dangerous. Really..............heart attack is the biggest risk for old guys like me on track. No I don't have a bad heart and I don't want one either.
If you could keep the AC running from a external power source (tow vehicle charging system and cable to SLC AC system via power source big switch on SLC) and keep the SLC in the shade between sessions it really COULD work.
I like these little compressors and would love to see a complete system in a SLC. No concern on over revving the AC compressor with these. For now we seam to be at the very beginning of a new product development cycle. It will be very interesting to see what a year or two will bring.
Old 8th April 2015, 05:21 PM   #55
YerDugliness's Avatar
YerDugliness
GT40: 1/24 scale MKII
I think electric powered devices are terribly underused....think of the power you could free up if you'd use an electric motor to power your A/C, Power Steering and power brakes!
Sure, you might need a heavier-duty alternator/battery, but like I said, if it freed up some power to make the car faster, wouldn't it be $$ well spent? How much would you have to invest in engine parts to get an equal increase in power?
Cheers!
Doug
YD,E./PNB
Als RIGHT...Buy American!!!
Retired twice, now back at work, but still attempting to age disgracefully
YerDugliness is offline   Reply With Quote
Old 8th April 2015, 06:45 PM   #56
YerDugliness
Originally Posted by awatkins View Post
BTW, none of you commented on the tail lights. I got a set for my GT40.
I did in post number 17.
Originally Posted by YerDugliness View Post
I was admiring the replacement stop/tail light.
Doug
YD,E./PNB
Old 19th April 2015, 07:57 AM   #57
Mal
malb
This thread started with trying to fit an AC compressor at the front of the engine into the engine compartment. Do you need the AC due to heating up while stationary, or do you need it on the road/track? If the latter, what portion of time is spent mobile vs stuck at traffic lights/ sitting on the start line etc?
Having read through the thread from end to end, I recalled a Lola T70 running in OZ about 7 years ago where the alternator was installed on an accessory mount at the gear box and belt driven from a pulley on one of the drive shafts. I don't know if this was the primary alternator for the car, or a secondary one added to supply additional electrical power.
Depending on combinations of climate, and operating patterns, a similar arrangement mounting a traditional mechanically driven compressor may work.
malb is offline   Reply With Quote
Old 19th April 2015, 03:44 PM   #58
Mark IV
I Have No Life
GT40: Superformance
[QUOTE=malb;468954]Having read through the thread from end to end, I recalled a Lola T70 running in OZ about 7 years ago where the alternator was installed on an accessory mount at the gear box and belt driven from a pulley on one of the drive shafts. I don't know if this was the primary alternator for the car, or a secondary one added to supply additional electrical power.
QUOTE]
That was quite common with race cars in the 60s. In fact DeTomaso did the Mangusta that way as they ran out of room at the front with the AC compressor there.
Obviously race cars don't idle for long so lack of power generation while stopped is not a concern.
Old 3rd June 2015, 10:09 AM   #59
Dee
fdbgt
"I just bit the bullet and bought one of theirs. Saves time and frustration!"
Dave L., I started researching DC-powered AC systems and stumbled across this thread. I have a small mid-engined car that is also a challenge when adding an AC compressor w/o hacking up the firewall so I am interested to see what develops here. Its seems that you chose what is sometimes referred to as a "supplemental" system due to the BTU rating, correct? I imagine because of the smal interior space of the Lotus. I hope you will report back with any findings.
fdbgt is offline   Reply With Quote
Old 3rd June 2015, 08:44 PM   #60
dlindemann's Avatar
dlindemann
GT40: Lotus
I have the unit in my shop but haven't had time to do anything with it. The compressor unit is very small but I spoke with Sean at SHM and he assured me that it will be more than enough for the small cockpit of the Lotus. I'll report back once I have had a chance to work on it.
Dave L
Forum Jump
Similar Threads
A/C compressor problems Bigblockquad Superformance GT40s 8 6th July 2008 03:43 PM
Installing the AC compressor Bill D RCR Forum - RCR40/SLC/917/Superlite Aero 7 7th March 2007 12:11 PM
Where are you mounting the AC Compressor? Bill D GT40 Tech - Engines/Induction/Exhaust 9 16th November 2006 06:04 PM
compressor for sale Malcolm The Paddock 0 8th July 2004 01:54 PM
12V Air compressor Paul Bearman GT40 Tech - Engines/Induction/Exhaust 7 24th July 2003 09:57 PM
