Hey no problem, it's all good discussion!
Yeah, I saw a lot of cars at the weekend with the LED lights on all the time. It's a good idea, but not if you've got festoon bulbs! I got pulled over by the traffics a few weeks back and they did a light check (just being nosey I think) and the front off-side sidelight wasn't working. I knew it should be, as I literally checked it before I went - I even took the cover off, stripped the light and put a cable tie around the arms that hold the bulb in. But there it was......10 miles after doing this and the light was out again. I walked around to the front of the car, banged on the front corner and the light came on. It seemed to keep plod happy, but it was then I decided I needed some better lighting solutions!
I recently bought LED rear number plate lights and they are brilliant. There must be something similar, a marker light or similar that we could use?
I'm gonna start digging.......
