Old 11th August 2010, 03:58 PM   #1 (permalink)
trevorsummers's Avatar
trevorsummers
8 Tenths
GT40: Tornado TS40
Aluminium fabrication required
Hi all
I am looking for a company or individual to help me with part of my build. I have 2 aluminium lids and 2 aluminium panels that need some cutting doing.
The lids require some rounded corners and the panels need 2 sections to be cut out again with rounded corners. I would do this myself but I want the corners & edges to be perfect and don't think I'll do a very good job.
Here is a picture of one of the lids that needs cutting:
I am based in Warwickshire so if anyone knows of anywhere/anyone in the area that can help that would be great
Many thanks
Trevor
----Trev----
google_ad_section_end -->
trevorsummers is offline
Old 11th August 2010, 04:53 PM   #2 (permalink)
RichardH's Avatar
RichardH
5 Tenths
GT40: GTD+
Re: Aluminium fabrication required
I have someone local to me - or might know someone in Woking, but just realised that isnt local ..
RS built GTD+
Engineering Manager, trying desperately to find out how these things work!
RichardH is offline
Old 11th August 2010, 05:07 PM   #3 (permalink)
David Morton's Avatar
David Morton
GT40: The Jewel on th
Arborfield near Reading any good?
David Morton is offline
Old 11th August 2010, 05:31 PM   #4 (permalink)
Clivec
GT40: scratchbuild
A bit of an off-centre answer.
I have a sign manufacturing shop, and regularly machine out this sort of job on my CNC flatbed mill. 4ft x 4ft, and have done up to 32mm thick alloy for gaskets, adapters, brackets, mounts etc.
Could be worth ringing around local sign businesses to see if any of them have a bit of petrol in the blood and are willing to help you out.
Would be a 20 minute job if you walked in my door, but the air fares would be killing.
Clivec is offline
Old 12th August 2010, 03:50 AM   #5 (permalink)
Brett James-McCall Moderator
brettmcc's Avatar
brettmcc
I Have No Life
GT40: RSGTD
Try Bryn at Allyfab here: AllyFab Contact
He's also a GT40EC member
brettmcc is offline
Old 12th August 2010, 05:01 AM   #6 (permalink)
trevorsummers
8 Tenths
GT40: Tornado TS40
Thanks Brett will give him a call
Trevor
----Trev----
Old 12th August 2010, 05:18 AM   #7 (permalink)
Jon
jonnyb's Avatar
jonnyb
5 Tenths
GT40: Tornado
I believe he is also building a Tornado. So may be able to give some advice.
jonnyb is offline
Old 12th August 2010, 07:04 AM   #8 (permalink)
saxoncross's Avatar
saxoncross
GT40: Tornado
Hi Trevor,
<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com<img src=" /><o:p></o:p>
What you’re asking for is very basic fabrication and you should be treating this as part of your learning curve on the car.<o:p></o:p>
<o:p></o:p>
A few key points that may be of use:<o:p></o:p>
  • Practice on scraps until you feel confident on the actual parts<o:p></o:p>
  • Accurately mark the radius with a scriber<o:p></o:p>
  • For the external radius cut roughly to shape with tin snips or a jigsaw<o:p></o:p>
  • For the internal radius cut roughly to shape by chain drilling or a jigsaw<o:p></o:p>
  • Finish with either a hand file or a powered rotary burr (sanding bobbin)<o:p></o:p>
<o:p></o:p>
It may take a little longer, but you’ll get more satisfaction out of your build. I’ve just build my own exhaust system, never done one before and I can now proudly say I did that!<o:p></o:p>
<o:p></o:p>
Regards<o:p></o:p>
<o:p></o:p>
Andy<o:p></o:p>
saxoncross is offline
Old 12th August 2010, 07:05 AM   #9 (permalink)
Mark Pickford's Avatar
Mark Pickford
GT40: GT40 Arch Rival
Hi Trev,
A friend of mine is based just outside Stratford on Avon and builds Dragsters and Hot Rods mainly. His fabrication skills are awesome.
This job would be a doddle for him if his schedule allows him the time to fit you in.
I'll PM you his tel number.
Mark Pickford is offline
Old 12th August 2010, 08:41 AM   #10 (permalink)
P2164's Avatar
P2164
GT40: SPF 2164 07-07
Check for anyone with a water jet, that is short work for a cnc abrasive water jet cutter.
SPF GT40 MK1
and a bunch of other stuff
Typing is not my bag
P2164 is offline
Old 12th August 2010, 08:58 AM   #11 (permalink)
trevorsummers
8 Tenths
GT40: Tornado TS40
Originally Posted by saxoncross View Post
Hi Trevor,
<o:p></o:p>
<o:p></o:p>
<o:p></o:p>
<o:p></o:p>
Regards<o:p></o:p>
<o:p></o:p>
Andy<o:p></o:p>
I've done some practice curves using a jigsaw and file and know I could probably do a reasonable job myself but I'd rather trust someone else to get a better finish.
Trev
----Trev----
Old 12th August 2010, 11:47 AM   #12 (permalink)
trevorsummers
8 Tenths
GT40: Tornado TS40
Thanks for the suggestions guys
Going to try Marks guy in Stratford-upon-avon as he is just up the road and sounds like he knows what he's doing. Panels due to go to him next week so I'll keep you posted on the results
Trev
----Trev----
Similar Threads
Merge Collector Fabrication JIMMYMAC GT40 Tech - Engines/Induction/Exhaust 8 18th July 2009 08:05 PM
New aluminium Cobra in UK RobBeddington Vendor and Manufacturer Announcements 0 17th April 2006 06:59 AM
Flywheel fabrication alanrayner GT40 Tech - Engines/Induction/Exhaust 6 7th December 2005 09:10 AM
Aluminium uprights Paul Bearman All GT40 15 10th April 2002 06:49 AM
Aluminium trim for GTD Paul Bearman GT40 Cars For Sale 0 16th February 2002 12:35 AM
