Rear window template
Hi all
I recently received my rear window for my Tornado. The window shape is marked onto the window ready for cutting and as standard comes as a rounded shape (see picture below).
attachment.php
However I want my car to have the more authentic triangular shape as per the orignal cars
Does anyone have any sort of template or could provide a high resolution image of their rear window cut out so I can plan the shape on my window. Also have any other tornado owners done this in the past?
Trevor
David Morton
Trevor, Use the rear bodywork as the template - On the GTD it is the correct shape for the window, though I'm unsure about the tornado product. I too think the rounded ends are ...........
well, just that. Rounded ends.....
Andy at Tornado say the rounded shape is to make the window fitment easier which I can totally appreciate as I can imagine its a tricky job but as with everything so far I want the window to look as per the originals. David if you have images of the GTD shape or other rear windows can you post them up
Trevor
David Morton
I would mean a drive to go and get a copy of mine as it's over in Arborfield near Reading. Do you have a rear body section yet? Or do you know anyone that has?
All I did was taped a piece of harboard across the rear section roughly where the window would be and marker penned the hardboard. Then I had a template to work from - my brother supplied some cut to the template fancy glass from the aeroplane industry and Henry Atherton (who built the Safir tubs) made a rubber template and an aluminium surround for it and welded the surround into the car and fitted the window.
David Morton
OK - ask around if anyone has a similar car to the one you are building in the midlands area ? You can come and copy mine if you want but it's a bit of a treck for you.
Just found some photos - I'll try and upload them.
Trevor as David says the window should match the plenumb on the rear clip - might be worth waiting till you have the clip as the alignment is slightly different on every car. I can trace around the window on my car and post you it if you can't wait - if so pm me.
David Morton
window in situ
Hey Paul
Just looked at your build pictures, your rear window shape looks perfect. If it's possible for you to trace round the window to create a template that would be great.
Andy at Tornado advised cutting the window before I rivet the rear bulkhead into place so ideally I need to do it sooner rather than later as I am planning on getting all the panels to the powder coaters before xmas. I'll pm you my address paul
Trevor
Seymour Snerd
Trevor --
E-mail or PM your address and I can send you a tracing of the rear window from my SPF. It's not in the car so it's very easy for me to do.
Alan Watkins
Hi all
I received two templates from Alan Watkins & Andy Green which was a massive help. Together I've combined the templates to use Andy Greens measurements and radius' and copied Alan's curvature at the top of the window to create my current template.
The template shares the same tallest point and same widest points as of that provided by tornado.
Here is the standard tornado shape for reference
What do you think, will this work and does the shape look correct?
Trev
Charlie Farley
Alan,
For what it's worth. I supplied a template of that rear window to the builder of a reproduction of an ' original ' chassis. Don't believe the hype. Its very different to certain so called 'exact' copies of 'original' cars, with '98%' compatabitily issues.
i can only guess that econimic issue come into play at some point.
Seymour Snerd
Alan,
Andy --
Sorry I'm not quite following you. You're saying that the SPF window outline is quite different from that of an "original" GT40? If so I'm just curious: how/where does it differ?
And by "certain so called 'exact' copies of 'original' cars, with '98%' compatabitily issues." what exactly are you talking about? Is some replica claiming 98% accuracy?
Trevor,
Just remember that wherevere you gett the glass from to get it with the correct E mark...
Brett
Hey Brett
The rear window has been supplied by Tornado so this should be fine. It's not glass but seems to be some kind of plexiglass.
Trev
