Go Back   GT40s.com > >
Thread Tools Display Modes
Old 24th March 2011, 06:23 PM   #1
GT40: Glasgow, Scotland
Help Needed to Identify Stering Column
I'm looking to change the steering wheel that I currently have in my car. The problem is I don't know which donor car the coloumn is from and the current wheel has been 'heavily modified' to fit. The kit was a scratchbuild that I got in boxes....so I can't refer back to any manufacturer.
The shaft has a thread at the end for the nut that secures the steering wheel, then there is a parallel splined section (about 22mm diameter), then behind that there is a smooth tapered section.
I can try and get a pic if it helps, but does this sound familiar to anyone? Basically I just want to fit a nicer looking steering wheel, but when I check online to buy something I seem to be drowning in options for all diferent types of boss, adaptors and quick release systems. One of my friends suggested buying a kit where I just chop the end of my column and weld on a new hex or d-shape adaptor that comes with a kit, but I'd prefer to just order the right adapter that fits.
Thanks in advance for an help you can offer.
Mark McCaughran is offline   Reply With Quote
Old 24th March 2011, 08:09 PM   #2
zetecmk2
3 Tenths
GT40: pile of bits!
Re: Help Needed to Identify Stering Column
you could be describing an old ford mk1/2 escort or cortina mk3/4/5 but i have a scimitar gte column that looks similar....triumph maybe?
locost,,,oh yes!!
zetecmk2 is offline   Reply With Quote
Old 25th March 2011, 04:58 AM   #3
you may be right....someone even suggested Marina/Ital.....(scary to think what connects me to the car might be a Marina part!!!).
I'm struggling with how to check. Maybe the chop and weld idea would be easier.
Old 25th March 2011, 05:23 AM   #4
Brett James-McCall Moderator
brettmcc's Avatar
brettmcc
I Have No Life
GT40: RSGTD
Mark,
Why not go for the weld-on option? That way you can take the wheel off when you get in and out and gives you more space?
Brett
brettmcc is offline   Reply With Quote
Forum Jump
Similar Threads
Help Needed to Identify Ford Engine Mark McCaughran GT40 Tech - Engines/Induction/Exhaust 8 11th February 2010 02:49 PM
Steering column splines simonjrwinter GT40 Tech - Chassis,Brakes,Tires,&Wheels 2 5th March 2009 01:56 PM
Steering Column PETER HILL The World Market - Share Parts, Sources, and Reviews 0 22nd April 2007 07:06 AM
which steering column to use??? linder GT40 Tech - Chassis,Brakes,Tires,&Wheels 0 29th August 2004 03:35 PM
steering column mike_starling GT40 Tech - Chassis,Brakes,Tires,&Wheels 3 5th July 2003 05:02 PM
