Go Back   GT40s.com > >
Thread Tools Display Modes
Old 4th May 2011, 08:23 AM   #1
Geoff Deakin
2 Tenths
GT40: KVA C-Type Mk I
Side window opening flaps
Hi All,
I've just fitted my first door window - Very nerve wracking!
I now need to drill holes in the centre of the window (!) to mount the hinges and latch for the opening flaps.
I've drawn every pattern of holes possible to get everything to line up.
I'm still terrified of drilling the first hole in the wrong place!
Has anybody got any ideas?
Short of drilling it for me!!!
Hoping to hear from you all.
Cheers,
Geoff.
At last!
KVA - 302 - Renault 'box
Geoff Deakin is offline   Reply With Quote
Old 4th May 2011, 02:56 PM   #2
awatkins
GT40: N/A
Re: Side window opening flaps
I know the feeling well. Actually it's the 2nd through Nth holes that always cause me grief. The only idea i've got is to tape (or something) the bezel in place and "drill through" it as a template.
The psychological trick I use in this situation is to know what it would cost to start over with a whole new window. Then I tell myself "OK, at worst this will cost you $X to start over".
And then there's Valium....
awatkins is offline   Reply With Quote
Old 5th May 2011, 06:50 AM   #3
Clivec
GT40: scratchbuild
Geoff,
On the assumption the windows are acrylic (perspex), may I pass on my experience as a sign fabricator.
1. Dosn't seem to matter how sharp the drill is, just make sure that the material is held down HARD on the backing material as the drill comes out the bottom of the hole.
2. As far as possible, drill the hole to the finished size. Avoid drilling 'pilot' holes and then enlarging.
Clive
Clivec is offline   Reply With Quote
Old 8th May 2011, 10:25 AM   #4
Geoff Deakin
2 Tenths
Hi Alan and Clive,
Thanks for your replies.
I managed to drill the window mounting holes with a 3mm drill, and then open out the holes to 4mm and then countersink the holes for ss screws.
To my horror I split the bottom rear corner of the window with the 3mm drill, but have managed to superglue the peices together, and with a bit of tidying up, is should look okay - but you should have heard the language!
My concern with drilling for the hinges and latch for the flaps is drilling the holes in the correct place at the first attempt.
Everybody on the forum must have done this, and I'm just looking for the best way to plan this.
Perhaps I should make a mock up, to get the hingle angles and positioning correct?
Still looking for ideas.
Cheers, Geoff.
At last!
Old 8th May 2011, 04:50 PM   #5
Bernie Knight
GT40: GT40 Aust. #64
Geoff
I picked a few scrap pieces of perspex out of the waste bin from the plastic supplier to experiment with.
I tried the fast drill method versus slow and steady. Then I used a hole saw. I even tried using a small saw. The practice and straight cutting prepared me for the final cut, which turned out great.
Just go slow as the perspex will crack when you get near an edge - as your found out.
Under the heads of the bolts that I used, I placed a small rubber washer and pulled the bolts tight until I felt the rubber compact slightly. This tops rattles and bolts contacting the perspex.
Good luck.
Gone for a drive, back in an hour
Bernie Knight is offline   Reply With Quote
Old 8th May 2011, 04:55 PM   #6
awatkins
GT40: N/A
And maybe these would help:
Plastic Drill Bits for Plexiglas, Lucite, Acrylite - chip-free drilling
Old 9th May 2011, 01:29 PM   #7
Mark Charlton's Avatar
Mark Charlton
Canada
GT40: GTD #9988
Geoff,
If the concern is the holes drifting when you are drilling them, you can reduce the chances by making a drilling template from .125" aluminum and clamping it with some hardwood and the plastic in between.
You pre-drill the aluminium in a drill press (suitably clamped) and verify the fit by test-installing your hardware to it. Once happy, clamp and drill the final parts (one template flipped will do both windows). The aluminium will act as a guide and almost eliminate drift while the hardwood will prevent break-through cracking you experienced previously. As Clive noted, it is the back support (where the drill bit exits the plastic being drilled) that is critical (I also run a signage fabrication shop). Oh, and using a small amount of oil or water when drilling will help. Go slow and you'll be fine.
Mark
Mark Charlton
____________
GTD40 #09988
71 DeTomaso Pantera #1826
71 DeTomaso Pantera #2281
70 DeTomaso Mangusta #1114
Mark Charlton is offline   Reply With Quote
Old 10th May 2011, 04:04 AM   #8
Bernie Knight
Mark
Sorry yes, I should have mentioned to Geoff that I place a masking tape - adhesive paper - to the perspex and mark each bolt/screw hole. This tops the drill drift and splintering.
The drill press is even better.....
Forum Jump
Similar Threads
Removable / opening GT40 side Windows IanAnderson GT40 Tech - Exterior, Interior, AC, & Trim 40 4th August 2008 05:04 AM
How do you get paint in the opening at rear window? Jeff Hamilton GT40 Tech - Exterior, Interior, AC, & Trim 1 28th March 2008 08:05 PM
mk3 window opening daveb GT40 Tech - Exterior, Interior, AC, & Trim 1 8th November 2005 10:40 PM
dimension of bulkhead window opening iraceone GT40 Tech - Exterior, Interior, AC, & Trim 2 24th August 2004 04:10 PM
Opening side windows? cinqster All GT40 7 7th December 2002 04:16 PM
