Dino
I used standard mats that I then cut down to a template for each footwell made from cardboard. I removed the edging trim first, cut them to fit and then restiched the edging. I would recommend anchoring them somehow as they do move around otherwise. It's about time I redid mine as they are starting to look a bit worn now. If you really wanted to go the whole way there are companies that will make mats for you if you send in a template and even add a logo of your choice (within reason) search on ebay.
