Assuming you are talking about aluminum panels that are normally rivetted to the structure of a space frame -
On cars that I have built, I overlap by the width of the supporting tube or 1" whichever is less. I also typically use silicone RTV between the panels at the overlap, but have also used epoxy at times.
Hope that helps..
