My front clip on one side in particular (other side is pretty good) has a bit more curve to it than I think it should. I can get the clip and sill to mate by using a latch but the clip side radius doesn't match up to the side sill.
The photos explain it best.
What would you suggest? Leave it as is (not all that bad really), add material to the back of the clip and grind down the outer face, or add material to the side sill to bring it out a bit?
I spent two hours tonight starting on option 1 but it would need much more done to it than I did if I want it to match perfectly. Looks like the clip would need about 1/4" or so removed.
