Go Back   GT40s.com > >
Thread Tools Display Modes
Old 10th June 2014, 10:22 AM   #1
Gmen
Silver Supporter
GT40: CAV GT40
CAV door weatherstrip
I am trying to locate door weatherstrip for 2002 CAV GT40. Tried CAV dealer, no luck. Any leads would be greatly appreciated.
Thanks, Gene
Gmen is offline   Reply With Quote
Old 10th June 2014, 11:18 AM   #2
Pat
Veek's Avatar
Veek
Silver Supporter
GT40: CAV
Re: CAV door weatherstrip
Try here:
McMaster-Carr
Look at the section on edge grip seals.
VEEK
CAV #04
Florida
Veek is offline   Reply With Quote
Old 10th June 2014, 02:33 PM   #3
Ellis Hubbard
GT40: Cincinnati, Ohi
Hi Gene, who is the CAV rep today?
Ellis Hubbard is offline   Reply With Quote
Old 11th June 2014, 11:59 AM   #4
tractorboy
GT40: CAV # 82 SOLD
Ellis, it remains Johann Keyser (in the USA) and has done for years.
HOME
tractorboy is offline   Reply With Quote
Old 11th June 2014, 09:44 PM   #5
Mark Charlton's Avatar
Mark Charlton
Canada
GT40: GTD #9988
When I replaced the seals on my GTD, I bought a roll of door seal from Trim-Lok. It was a perfect replacement and even left me enough to do my Pantera. Not sure if the CAV will be the same, but I suspect it will be close.
Co-Extruded Trim Seal - Trim-Lok
Mark
Mark Charlton
____________
GTD40 #09988
71 DeTomaso Pantera #1826
71 DeTomaso Pantera #2281
70 DeTomaso Mangusta #1114
Mark Charlton is offline   Reply With Quote
Old 3rd July 2014, 09:24 AM   #6
Johann's Avatar
Johann
GT40: CAV GT
Thanks, Gene
I was never contacted about any "door weatherstrips" for a CAV GT and I am the only CAV dealer in the USA. I am sure that I have the correct information regarding a "weatherstrip for a CAV GT.
Johann Keyser
www.cav-america.com
Johann is offline   Reply With Quote
Old 24th August 2016, 03:31 PM   #7
Pat
Veek's Avatar
Veek
Silver Supporter
GT40: CAV
I thought I needed new weatherstripping where I squeeze into the drivers door in the confines of my garage and occasionally pull the strip off with my posterior. It turns out two minutes with a pair of slip joint pliers tightened the grip bands to get it snug as new.
VEEK
CAV #04
Florida
Old 25th August 2016, 10:52 AM   #8
Michael K.
GT40: CAV GT
I believe the stock material was employed on BMW's built during that time frame. You can likely compare the material you have with that employed on BMWs of that vintage and then determine which BMW model employed a piece long enough for the CAV.
Michael K. is offline   Reply With Quote
Old 23rd September 2016, 09:29 PM   #9
gsharapa's Avatar
gsharapa
GT40: CAV #169
My CAV also has the BMW weather strips on it.
Gary
gsharapa is offline   Reply With Quote
Forum Jump
