Go Back   GT40s.com > >
Thread Tools Display Modes
Old 16th November 2016, 09:24 PM   #1
darrinps
8 Tenths
GT40: GTForte
What would you do? Door mechanism
I am trying to connect the latch to the catch. The latch hinge sits above, to the left, and slightly rearward of the mechanism's swing arm upper attachment point. I've tried simply bending a threaded steel rod, and although it comes close, it doesn't quite work right. I'm thinking a more intricate system may be needed.
How do people typically handle this?
Thanks.
What would you do? Door mechanism-mechanism-jpg
darrinps is offline   Reply With Quote
Old 16th November 2016, 10:49 PM   #2
Big-Foot's Avatar
Big-Foot
Administrator
GT40: Gulf Cart
Re: What would you do? Door mechanism
I don't know if this helps..
There does not seem to be a really good way to get the mini-bearclaw latches linked to the door handle.
http://www.gt-forty.com/GT-Forty/DOO...ases.html#grid
Regards - Randy
-- Youth and talent are no match for old age and treachery!
GT40 RCR40 #45 G50-331-Weber IDAs ((Sold))
My build site:
Old 16th November 2016, 11:18 PM   #3
darrinps
8 Tenths
GT40: GTForte
Thanks!
Think I have something figured out, but was hoping an easier way might already have been proven out.
Old 17th November 2016, 01:40 AM   #4
Big-Foot's Avatar
Big-Foot
Administrator
GT40: Gulf Cart
Yeah, mine (shown in the link I posted earlier) does work - it just doesn't work as well as I would like..
Regards - Randy
My build site:
Old 17th November 2016, 02:31 AM   #5
IanAnderson's Avatar
IanAnderson
GT40: Dax 40 Mk1 (Rov
I used a cable, inner bicycle brake cable from memory, without the outside sheath.
Hooped around one end and threaded through a hole at the other, and believe it or not adjusted for length with electrical "chocolate block" connectors
Worked very well for 10 years so far!
DAX GT40. Morgan 3.9 EFi, Worked by John Eales.
IanAnderson is offline   Reply With Quote
Old 17th November 2016, 11:05 AM   #6
darrinps
8 Tenths
GT40: GTForte
Thanks Ian. I was going down that path for a bit too when I stopped to try the bent threaded rod idea. I was using a stainless pulley at the top, and a stainless eye at the bottom. The cable went from the handle up through the pulley, down to the eye then up to the bear claw. It was adjustable at the eye and pulley, but it wasn't quite perfect and just looked too complicated to be reliable, although maybe it would be given your history.
I'm going to try an L shaped bracket attached to the handle that is adjustable for height and length via bolts. The bottom should align right with the bear claw and I'll build into that with enough play to allow for the arc (the handle travels straight while the mechanism on the latch goes in an arc).
If that doesn't work, it's back to the pulley set up with a 3/32" cable, no sheath, just like you were using.
Old 18th November 2016, 01:35 PM   #7
darrinps
8 Tenths
GT40: GTForte
Mocked up something similar to what Ian has and I think it's probably the easiest, and least complex solution. Going to bolt it up this weekend.
Thanks for the feedback folks!
Old 19th November 2016, 06:36 AM   #8
IanAnderson
Here you go
Post 130
DAX Build Up
Old 21st November 2016, 11:11 PM   #9
darrinps
8 Tenths
GT40: GTForte
Did what you did and it works fine Ian. I have a spring pulling the handle back into place but no rubber stopper. I just cut, and worked a piece of stainless angle to fit. Took a while to get it right but it's good to go now. I still have to install the locking/unlocking mechanism (I have a remote entry setup) but that should go easier.
Old 22nd November 2016, 09:49 AM   #10
Brett James-McCall Moderator
brettmcc's Avatar
brettmcc
I Have No Life
GT40: RSGTD
Darrin, here is a photo of mine: Brett's RS GTD
Southern RSGTD; Mexican block; Audi 01X
I love the company so much I work for them and build them in my spare time....
brettmcc is offline   Reply With Quote
Forum Jump
