Old 10-29-02, 01:26 PM   1 links from elsewhere to this Post. Click to view. #1 (permalink)
Rep Power: 0  is on a distinguished road
Removable Steering Wheel
I have little or no problem getting into my GTD but egress is another matter entirely what with my advanced age, tired bones and bad back. A suggested possible solution was to get a removable steering wheel. Anyone have any suggestions as to a source and positive/negative comments about installation. I've heard that some cause the steering wheel to protrude too far into the cockpit.
Your assistance, please,
Ben
 is offline
Old 10-29-02, 01:47 PM   #2 (permalink)
MK -IV J6's Avatar
MK -IV J6
GT40: NYC,USA
Re: Removable Steering Wheel
Dear Ben
I fit a tilt Fiero columm into my Lola which helps. I also think a removable one would work.
[ October 29, 2002: Message edited by: MK -IV J6 ]
MK -IV J6 is offline
Old 10-29-02, 04:03 PM   #3 (permalink)
GT40: Carmel, NY
Rep Power: 6 Specracer89 is on a distinguished road
Ben,
Here's a link I had saved away on a Q/R install in a BMW autocrosser:
http://e30m3performance.com/installs...ub/qr-hub1.htm
I know Strange Engineering, SPA, Momo and Sparco make quality hub/spline kits, the latter two geared for street cars. Make sure you don't get a hexagonal shaft-end, and get a splined-end. There is usually a lot more play in the hex models. Good luck.
Specracer89 is offline
Old 10-29-02, 04:13 PM   #4 (permalink)
wealdenengineer
Rep Power: 17 wealdenengineer has a spectacular aura about
Hi Ben, I fit removable wheels to most of our GTD in UK, simple and very effective. If you want necessart parts I need to know some details of your steering wheel etc. I assume you have the original GTD (Triumph) column. Frank
wealdenengineer is offline
Old 10-29-02, 05:20 PM   #5 (permalink)
Frank,
Not sure of the source of the column or steering wheel but they both came with the kit in 1989. I am definitely interested in whatever parts and assistance you may offer. You've saved me more than once.
Ben
[ October 29, 2002: Message edited by: Ben Miller ]
 is offline
Old 10-29-02, 07:17 PM   #6 (permalink)
Alain V
2 Tenths
GT40: sold them both!
Rep Power: 9 Alain V is on a distinguished road
I have removable splined shaft wheel on my SCCA racecar and am planning on also installing one in the GT40.
They are available throught racer supply places such as racer wholesale, pegasus, and truechoice.
Alain V is offline
Old 10-29-02, 11:24 PM   #7 (permalink)
Ben, If you want a removable steering wheel that maintains you turn signals and can fill up a standard sized hub, check the thread that I posted on the For Sale forum. raid HP Super Snap-off
I can send you some pictures of mine that is in place if you'd like. There are some pictures in the thread also
 is offline
Old 10-29-02, 11:40 PM   #8 (permalink)
3 Tenths
GT40: australia
Rep Power: 10 norman falkiner is on a distinguished road
Just be a little careful with registration requirements as in many areas removable steering wheels are not acceptable, and may deem the car unroadworthy. All the road going ones I know of were fitted later. Regards
norman falkiner is offline
Old 10-30-02, 03:26 AM   #9 (permalink)
wealdenengineer
For one upmanship, you no longer walk into a restaurant with your yuppie mobile phone, you walk in with your steering wheel! Ben, the system I use still retains the adjustability of the column, and will not move the wheel any nearer to you as some other systems do. Frank
Old 10-30-02, 04:48 AM   #10 (permalink)
Not discounting the comments above, to fit a removable steering wheel is quite simple. I have one on my car which I can assure you Frank did not fit!
There are basically two popular designs in the uk. One is a hex shaped based system and the other more similar to a spline as you would see on a gearbox input shaft. The former cost me about £45 and the latter £95. There are two parts to each system. The slug which requires to be welded to the steering column and then the attachment to which your steering wheel bolts on to. With steering wheel makes having different bolt patterns you need to ensure you get the right adapter kit as part of your purchase. If you have a really odd ball steering wheel then you can turn up an adapter quite easily on a lathe. I did this on our Lotus 51. A bit more than 5 minutes this time!
On the GTD standard steering column the slug on the hex type adapter slips over the existing spline at the top of the steering column perfectly. Either remove the column or be extremely careful, but just weld the slug in place making sure the fore and aft positioning is how you want it and that a reasonable penetration of the column up the slug is used.
To make the steering wheel point ahead you have the spline at the foot of the column for adjustment. Or just be jolly clever in your initial marking and alignment of the slug.
Dave Parker has a spline style adapter on his R42. This car has indicator stalks etc. However that has not prevented him making his wheel clip on.
I have both types of adapters fitted to cars in my garage. The Hex style one is easier to use but has a fraction more play in it as it only has the six mating surfaces. The spline style is fancier but is more difficult to use but once on is more precise. Having used both I would say the spline style adapter is better overall.
Trans Autosport (TAS) make a version of the the hex adapter and SPA make the spline adapter.
There are other adapters out there but these are the most commonly used items I know of.
A brief aside but having a clip on steering wheel helped me at Loton Park as with my car out of action, I was offered Julians car to drive. I only fitted his car with my steering wheel attached as it was a slightly smaller diameter than his but we had the same adapters so could swap in seconds. Very handy.
Hope this is of help
Malcolm
try searches at
www.tas.com www.spa-uk.co.uk www.demon-tweeks.co.uk
[ October 30, 2002: Message edited by: Malcolm M ]
 is offline
Old 10-30-02, 06:36 AM   #11 (permalink)
M.B
Marco Bjerkén
2 Tenths
Sweden
Rep Power: 9 Marco Bjerkén is on a distinguished road
Some brands are legal in some areas of the world, and some are´nt...
Like mentioned before...
Marco Bjerkén is offline
Old 10-30-02, 06:39 AM   #12 (permalink)
wealdenengineer
Ben, Safety is an issue here, and these "simple" jobs can bite you in a big way if it not carried out with care. Frank
Old 10-30-02, 08:14 AM   #13 (permalink)
Bigend's Avatar
3 Tenths
GT40: Surrey UK
Rep Power: 10 Bigend is on a distinguished road
Safety? What's that? Surely it is not neccessary to state the obvious.
Seriously folks, I would advise against the Hex type, as I have had one fail on me during an event. The "professionals" almost without exception use the splined type, which has a more secure location.
Bigend is offline
Old 10-30-02, 04:25 PM   #14 (permalink)
40bud's Avatar
40bud
6 Tenths
GT40: GTD Finished in
Rep Power: 13 40bud is on a distinguished road
Repco makes a nice spline type with a simple spring loaded pull up ring for release. It fit onto my GTD column nicely.
40bud is offline
Old 10-22-06, 10:51 AM   #15 (permalink)
simon jude
GT40: GTD 40
Rep Power: 2 simon jude is on a distinguished road
Smile Re: Removable Steering Wheel
Good Afternoon Frank,
have just read your thread posted in 2002 regarding removable steering wheels on GTD replicas - I have just purchased the GDT showcar that was built in 1988 -any chance of supplying me with the necessary bits to convert to a removable steering wheel ?
look forward to haring from you
many thanks
Simon Jude - Guildford Surrey
simon jude is offline
Old 02-04-07, 06:02 PM   #16 (permalink)
swede30's Avatar
swede30
Jim Dewar
GT40: RF 103
Rep Power: 6 swede30 is on a distinguished road
I need an adaptor/base for a Moto-lita wheel to fit my RF. I would be pleased to find an adaptor to fit their steering shaft or will weld to my shaft.
I ordered the standard bolt on Moto-lita wheel with my kit - big mistake! Is there a supplier for this item? Thanks in advance!
Jim Dewar
RF #103
C2 997 S
K 1200 GT
swede30 is offline
LinkBacks (?)
LinkBack to this Thread: http://www.gt40s.com/forum/gt40-tech-exterior-interior-ac-trim/9993-removable-steering-wheel.html
Posted By For Type Date
GT40s.com This thread Refback 10-22-06 01:14 PM
