| Notices | Hi member,
Enjoy the forum!
Why not start with your first post today and become an active part of GT40s.com now! And, if you find you enjoy GT40s.com think about becoming a Forum Supporter. | | GT40 Tech - Exterior, Interior, AC, & Trim All that other stuff not in categories above. |
08-26-04, 09:40 PM
#1 (permalink)
| | Bronze Supporter
Rep Power: 10  | Rear Deck Latch Handles. I've pulled the Tee Handle off the rod to open the rear deck. Does anyone have a source or suggestion for a replacement? Using pliers at the gas station is not at all stylish.
Thanks,
Veek |
08-28-04, 12:57 PM
#2 (permalink)
| | toner 8 Tenths
Join Date: Apr 2002 Location: Sundance, UT GT40: ex-CAV owner (stolen)
Rep Power: 15  | Re: Rear Deck Latch Handles. Make your own. That's what the milling machine is for. [img]/ubbthreads/images/graemlins/smile.gif[/img] |
08-28-04, 05:41 PM
#3 (permalink)
| | llarsen Admin
Rep Power: 29   | Re: Rear Deck Latch Handles. Veek,
Just out of curiosity, what Tee handle for the rear deck?? I don't recall seeing one of these on a GT40.
Lynn |
08-28-04, 06:33 PM
#4 (permalink)
| | Paul Bearman 4 Tenths
Join Date: Oct 2001 Location: UK, Kent GT40: Ex GTD40 owner,
Rep Power: 12  | Re: Rear Deck Latch Handles. I think early Mini bonnet latches were fitted to GTD40's so I assume that the pull cable & 'T' bar were from the same donor vehicle. |
08-28-04, 10:08 PM
#5 (permalink)
| | toner 8 Tenths
Rep Power: 15  | Re: Rear Deck Latch Handles. The CAV's have a pair of hood latches in the rear to provide a more secure hold-down than the side clips. You can see the engine compartment side of things here:
The release handle is made of plastic and has been known to break (or come off) [img]/ubbthreads/images/graemlins/shocked.gif[/img] |
08-29-04, 01:22 PM
#6 (permalink)
| | wbmusarra 10 tenths
Join Date: Oct 2001 Location: Snellville, Ga. GT40: DRB#5
Rep Power: 21  | Re: Rear Deck Latch Handles. I am considering the same release mechanism for my car. I plan to alter it a little by having a cable system and bell crank or pull mehanism similar to the BMW, forward and beside the drivers seat on the left. That way I can open both mechanisms from one location.
Bill |
08-30-04, 01:35 PM
#7 (permalink)
| | cward2 A Tenth
Rep Power: 8  | Re: Rear Deck Latch Handles. Bill,
That est up is exactly what ERA uses. When adjusted just right, you can pull the inside handle and both catches release at the same time. When adjusted just right is the key.
Chuck
ERA GT 2064 |
08-30-04, 01:40 PM
#8 (permalink)
| | toner 8 Tenths
Rep Power: 15  | Re: Rear Deck Latch Handles. I wasn't very clear in my post - the CAV actually has a separate handle for each latch. No cables, no adjustments, ... |
09-09-04, 08:08 AM
#9 (permalink)
| | 2 Tenths
Rep Power: 9  | Re: Rear Deck Latch Handles. I broke one of the handles on my CAV. I made a steel sleeve, painted it black and stuck the whole thing together with JB weld. looks good and works fine.
Vic
CAV 40 |
03-10-05, 12:22 AM
#10 (permalink)
| | Tom_Boy 2 Tenths
Rep Power: 9  | Re: Rear Deck Latch Handles. Veek, just broke one of mine fitting the rear clip. What did you eventually use for a handle? Thanks, Tom... I know I owe you a call.... |
03-10-05, 11:39 AM
#11 (permalink)
| | Lifetime Premier Supporter
Rep Power: 16   | Re: Rear Deck Latch Handles. Veek, I know Porsche used to use that type of "T" handle on the early 911/912/914's. Perhaps you could check your local dealer/wrecker for the handle and cable. |
03-10-05, 12:25 PM
#12 (permalink)
| | 5 Tenths
Rep Power: 10  | Re: Rear Deck Latch Handles. |
03-11-05, 04:02 PM
#13 (permalink)
| | Bronze Supporter
Rep Power: 10  | Re: Rear Deck Latch Handles. Tom,
I ended up using a handle from Pep Boys "Help" section. It is a generic hood release. I needed something that had the wire already bonded. It took a little trimming but it works fine. |
03-11-05, 05:11 PM
#14 (permalink)
| | 10 tenths
Rep Power: 26  | Re: Rear Deck Latch Handles. I hope you never wish you had done something like this. |
03-11-05, 05:12 PM
#15 (permalink)
| | 10 tenths
Rep Power: 26  | Re: Rear Deck Latch Handles. I liked the resulting piece of mine so much I did this to the front nostril cover. |
03-11-05, 05:14 PM
#16 (permalink)
| | 10 tenths
Rep Power: 26  | Re: Rear Deck Latch Handles. another angle |
03-11-05, 05:18 PM
#17 (permalink)
| | 10 tenths
Rep Power: 26  | Re: Rear Deck Latch Handles. Missed this one, I would be affraid to do it any other way. |
03-12-05, 05:27 AM
#18 (permalink)
| | wealdenengineer 10 tenths
Rep Power: 0  | Re: Rear Deck Latch Handles. We have just fitted a set of Aerocatches ( see www.AeroCatch.com or www.speciality-fasteners.co.uk ) to the rear deck of GTD40. These are very strong and positive locking units. Also we make replacement GTD and Cav slam catch cables with Tee handles. Frank |
03-12-05, 09:25 AM
#19 (permalink)
| | Dan Mattingly 2 Tenths
Rep Power: 7  | Re: Rear Deck Latch Handles. Frank, thanks for the links, really cool site! These Aerocatches look like the solution to the problem. They look like they were made for a GT 40. The size is perfect.The price is not bad either. I would spend more money in fuel chasing parts to make my own system. I saved the site for the US distributer for future use also! |
03-14-05, 08:51 AM
#20 (permalink)
| | brettmcc 10 tenths
Rep Power: 20  | Re: Rear Deck Latch Handles. FRank,
Any chance of a pic, or can I see when I come down?
Brett |
LinkBacks ( | |
