| Notices | Hi member,
Enjoy the forum!
Why not start with your first post today and become an active part of GT40s.com now! And, if you find you enjoy GT40s.com think about becoming a Forum Supporter. | | GT40 Tech - Exterior, Interior, AC, & Trim All that other stuff not in categories above. |
01-08-07, 08:50 PM
#1 (permalink)
| | Bill D I Have No Life
Rep Power: 35   | NACA Ducts I am opening up the two small NACA ducts on the fenders. How are they hooked up to direct fresh air the cockpit?
Bill D
__________________ Bill D
RCR GT40 Mk1 Gulf |
01-08-07, 09:01 PM
#2 (permalink)
| | Pantera1889 10 tenths
Join Date: Jul 2003 Location: Maryland,USA GT40: RCR MK1
Rep Power: 19   | Re: NACA Ducts Here's a picture of how Safir does it.
__________________ RCR GT40 MK1 chassis #14
DeTomaso Pantera #1889 |
01-08-07, 09:02 PM
#3 (permalink)
Rep Power: 19   | Re: NACA Ducts Another one for you .
01-08-07, 09:06 PM
#4 (permalink)
Rep Power: 35   | Re: NACA Ducts Thanks Ron. I guess I'll have the body man glass in an outlet to run a 3" hose to the cockppit
RCR GT40 Mk1 Gulf |
01-09-07, 10:56 AM
#5 (permalink)
| | Neal 8 Tenths
Join Date: Sep 2001 Location: Seattle, WA, US GT40: GT40 NZ
Rep Power: 16  | Re: NACA Ducts I cut 2 1/2 inch holes in the fender wells and made a fiberglas duct box that runs from the duct opening to the leading edge of the well. Post this picture I placed mesh over this opening to keep the critters out. There are flapper vents inside to regulate air flow into the cabin. Works like a charm.
__________________ GT40 NZ - 347 / Webers / Red and White - My build site
FFR Roadster #4867 408 / TKO / 3-Link |
01-09-07, 11:53 AM
#6 (permalink)
Rep Power: 35   | Re: NACA Ducts Thanks Neal. Where did you get the flapper vents?
Bill D
RCR GT40 Mk1 Gulf |
01-09-07, 12:36 PM
#7 (permalink)
| | llarsen Admin
Rep Power: 29   | Re: NACA Ducts Bill,
You can fab a flapper door from sheet metal pretty easily and use foam as a seal. To open and close it, you can use a vacuum motor and a vacuum solenoid to control it. They are availabe from VintageAir's catalog. Click 32.......Replacement System Parts. Here is a pic of the parts:
01-09-07, 04:06 PM
#8 (permalink)
| | Neal 8 Tenths
Rep Power: 16  | Re: NACA Ducts You can use a Y-valve to either block the inlet or redirect air between the vent and the defrost. Here is one source... Welcome To Nostalgic Air Parts
01-09-07, 05:17 PM
#9 (permalink)
| | Kalun_D 6 Tenths
Join Date: Dec 2003 Location: Seattle GT40: Scratch build
Rep Power: 12  | Re: NACA Ducts Quote: |
Originally Posted by Bill D run a 3" hose to the cockppit | calc the volume of your opening Bill, you should be able to get by with a 2 or 2-1/2 hose. You may loose velocity with 3", not to mention space savings. |
LinkBacks (?)
LinkBack to this Thread: http://www.gt40s.com/forum/gt40-tech-exterior-interior-ac-trim/20409-naca-ducts.html | | Posted By | For | Type | Date | | GT40s.com | This thread | Refback | 01-08-07 09:18 PM | |
