Old 02-01-07, 09:48 AM   1 links from elsewhere to this Post. Click to view. #1 (permalink)
JayPSC's Avatar
JayPSC
Deceased 5-24-07, RIP
GT40: RCR
Rep Power: 7 JayPSC is on a distinguished road
Spraying inside of fibreglass
I'm gonna spray the insides of the doors & clips now before I start clipping cables & stuff to it so I don't have to strip too much later.
Any particular paint I need to get or prep I need to do to get the paint to adhere? Just going for matt black.
Jay
Corrado G60 (For Sale)
Drift Volvo 760 Turbo
Z32 300ZX Twin Turbo
RCR40 in progress
JayPSC is offline
Old 02-01-07, 09:57 AM   #2 (permalink)
Bill Pinzini's Avatar
Bill Pinzini
GT40: RCR work in progress
Rep Power: 3 Bill Pinzini is a jewel in the rough
Re: Spraying inside of fibreglass
Jay, I used Dupli-Color Truck Bed Coating in a spray can.Just wipe with lacquer thinner and spray.
Bill Pinzini is offline
Old 02-01-07, 01:47 PM   #3 (permalink)
JayPSC's Avatar
JayPSC
GT40: RCR
Good plan, now just gotta find some in the UK.
Jay
RCR40 in progress
JayPSC is offline
Old 02-01-07, 02:10 PM   #4 (permalink)
Brian Magee's Avatar
Brian Magee
GT40: GTD
Rep Power: 12 Brian Magee is on a distinguished road
Jay
Go to decorators shop such as Brewers and buy some oil based paint. I use Blackfriars Semi Gloss Black. It is much easier than spraying and with the texture of the glass fibre you won't see any brushmarks.
Brian.
GTD, 289, ZF.
Brian Magee is offline
Old 02-01-07, 09:12 PM   #5 (permalink)
Keith1's Avatar
Keith1
I Have No Life
Cayman Islands
GT40: Nein
Rep Power: 27 Keith1 has much to be proud ofKeith1 has much to be proud of
Re: Duplicolor, this is UK based arm of US company who can get (and do keep stock here) Duplicolor products.
Caswell Europe, Electroplating and Powdercoating systems for small commercial workshops or home restorer
Yours Sincerely, Keith Hardy
Keith1 is offline
Old 02-02-07, 01:26 PM   #6 (permalink)
JayPSC's Avatar
JayPSC
GT40: RCR
Went for the Blackfriars satin black, seems to do the job just fine. I think I may have over estimated how much I needed though. The 2.5 liters I bought seems a bit much lol.
RCR40 in progress
JayPSC is offline
Old 02-02-07, 03:28 PM   #7 (permalink)
llarsen's Avatar
llarsen
GT40: Sabre
I guess I am a little late, but for others who may read this thread: If you want to smooth out the underside of you body panels before finishing, you may want to use a product like Evercoat Feather Fill polyester primer. In addition to the texture of the fiberglass, there were resin drips and grinder marks on the underside of my body panels which I found very unsightly.
This is a sprayable two pot filler/primer that is sandable and fairly easy to apply. I used an inexpensive gravity fed HVLP gun to apply mine and was very pleased with the result. (Trust me, I am NO painter!!) There are other products like, Evercoat Slick Sand, but it was only available in quart cans which cost almost as much as a gallon of Feather Fill. And, as far as I could tell, the two products were identical. Although this product was claimed to be comapatible with all topcoat systems, be sure and check it out with what ever you top coat with. Others make similar products as well.
In the engine compartment, I used a high heat Duplicolor product in aluminium for reflectivity. Every where else, including the chassis pan, I used 3M Rubberized Undercoating (NOT the plain 3M Undercoating or other types of undercoating! These can be a mess and many aren't much more than black paint. The NAPA brand rubberized stuff never fully cured was awful.) I wanted a build up for sound and chip protection. If I had it to do over again, I would have taken it to Line-X and had their bedliner material sprayed on (it doesn't have to have the deep texture like a truck bed.) The reason I say Line-X is that at the time I was researching this, that was what all the competion auto audio guys were recommending. Since product development is so rapid, it would probably be a good idea to see what those guys are using when you are ready to do your car.
Lynn
Sabre GT40/5L EFI/G50/50
Always verify parts or products discussed for your own use.
llarsen is offline
Old 02-02-07, 03:30 PM   #8 (permalink)
JhnC40
GT40: Tornado
Rep Power: 3 JhnC40 has a spectacular aura about
Pity you're not nearer 'cos I would take some of the paint off your hands as I was thinking of redoing my front/rear clip interiors too. Suppose 1 litre would be enough as it is only a paint over job.
John
Tornado TS40
Lotus Europa
Porsche 911 (now sold)
JhnC40 is offline
Old 02-02-07, 04:18 PM   #9 (permalink)
Mark Clapp's Avatar
Mark Clapp
4 Tenths
GT40: Mark I (South Africa)
Rep Power: 12 Mark Clapp is a jewel in the rough
I'm with Brian on brushing on the paint. I feel it does a better job of working into the uneven surface. Mine has been great for over 5 years now. I used Rust-oleum, which flows out great and leaves no brush marks. This eliminated the need to mask other areas and to tape the edges. No runs either.
Kit Car Centre Mk I (South Africa)
Mark Clapp is offline
Old 02-03-07, 12:10 PM   #10 (permalink)
JayPSC's Avatar
JayPSC
GT40: RCR
You'll get away with 500ml tbh, I've used hardly any doing the whole rear clip.
RCR40 in progress
JayPSC is offline
Old 02-03-07, 04:54 PM   #11 (permalink)
wbmusarra's Avatar
wbmusarra
GT40: DRB#5
Rep Power: 21 wbmusarra is a name known to all
I went by one of the Line-X dealers a couple of days ago. I have to say I like their product. It goes on hot and will seal any small gaps(if you want them to). I was thinking of doing the underside of the car because I had seen some surface rust in the cabin area. Close inspection found some small pin holes at some of the welds in the flooring. I hadn't thought of lining the underside of the clips, but it seems to make good sense to do so. It will get rid of the exposed fiberglass fibers that are everywhere and put a nice finish on it to boot. Their stuff comes in any color you might want to do. I am thinking of doing the few exposed large frame ladder pieces in the rear that didn't get the stainless treatment.
DRB#5
wbmusarra is offline
Old 02-04-07, 12:17 AM   #12 (permalink)
Location: past owner of t70\'s 71/40; 71/46; 75/122; 73/115; 73/131; t160 /2; t162/14 and gt40 1086; aswell as a gagle of cobras and corvettes
GT40: oregon
Rep Power: 4 jerryweichers is on a distinguished road
More important than the paint is preparing for the paint so it will stick. You need to find out from the manufacture what type of resin he used .... type ''a'' or ''B'' if the resin he used has wax in it... whatever you use won't stick without the proper prep. then after preping use a primer like DP40 or the equal and then the paint will stick . Its all in the prep!
jerryweichers
jerryweichers is offline
Old 02-04-07, 01:13 AM   #13 (permalink)
actvpwr's Avatar
actvpwr
GT40: Active Power FI
Rep Power: 4 actvpwr will become famous soon enough
Lizard Skin is a good product expecially where heat is an issue. Lizardskin Ceramic Insulation and Sound Control Spray-on Formula
Chris
Historic Race Car Replicas
actvpwr is offline
LinkBacks (?)
LinkBack to this Thread: http://www.gt40s.com/forum/gt40-tech-exterior-interior-ac-trim/20666-spraying-inside-fibreglass.html
Posted By For Type Date
GT40s.com This thread Refback 02-01-07 02:06 PM
