Well I'm finally getting to that point where its time to hook all the wires up to something!. While the engine was going together we talked to Jay at Motec USA. We were debating whether to actually install crank and cam sensors or to use a EFI distributor that would send the info to the Motec unit. He recommended a MSD 8455 distributor. The idea was to not actually use the distributor for the spark plug wires, (thats what the coil packs are for) but to get the info on the crank and cam shaft from the distributor. Sounds almost too good to be true. Anyway when it came time to hook it all up there were six wires coming from the distibutor. The distibutor came with no schematics, so I called MSD up and asked them to send me them. What I got was Wire #1 = profile ignition pickup, #2 = SPOUT / SPARK output (always pink), #3 = I.D.M. (ignition diagnostic module), #4 = HOT/START/RUN (eec power relay), #5 = COIL NEGATIVE (C-), and #6 = IGNITION GROUND. I then called Jay of MOTEC back to ask which goes to the corresponding inputs for the MOTEC engine harness. I was told that REF = Crank sensor and SYN = cam sensor. He had no idea what the MSD lead nomenclature ment. He suggested I fax him the schematic which I have done. I have yet to hear anything from MOTEC. I then called MSD support and asked what the above leads ment and which one was the crank sensor and which one was the cam sensor. To my complete suprise, they had no idea!! /ubbthreads/images/graemlins/shocked.gif They suggested I call a Ford dealership and talk to a mechanic. The local dealship was dumbfounded as well /ubbthreads/images/graemlins/frown.gif. Perhaps Jay of MOTEC will eventually figure this out and call me but I thought I would poll the forum and see if anyone had any ideas on how to link the crank and cam info from the distributor to the MOTEC M800 unit.
