Fuel Valve Switching
Hi All,
I'm hoping someone has the gadget I need. Unfortunately I don't know what they are called.......I'm running separate selectable lift pumps from each fuel tank into a swirl pot that contains a high pressure injector pump inside it and I'm looking for electric fuel switching valve to selectively switch the fuel return ( from the fuel rail and excess in swirl pot ) back to the tank that is running the lift pump from
Any suggestions would be appreciated.
Thanks in advance
:thumbsup:
Hi John
I have done a system similar to yours. I used two cut off valves used for immobilising vehicles to direct the return flow to the tank from which fuel is drawn. It is installed and working though time will tell if the constant flow through the low pressure pump will shorten their life.
The diagram is attached
Steve
Peter Delaney
John, I used the DRB recommended 6-port change-over valve :
<TABLE style="WIDTH: 149pt; BORDER-COLLAPSE: collapse" cellSpacing=0 cellPadding=0 width=198 border=0 x:str><COLGROUP><COL style="WIDTH: 149pt; mso-width-source: userset; mso-width-alt: 7241" width=198><TBODY><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-RIGHT: #eae6dd; BORDER-TOP: #eae6dd; BORDER-LEFT: #eae6dd; WIDTH: 149pt; BORDER-BOTTOM: #eae6dd; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" width=198 height=17>Ashdown 6 port fuel valve 27-90106 (Harness = 27-90107)</TD></TR></TBODY></TABLE>
You can see a pic & some specs on page 7 of this catalogue :
http://www.ashdown.com.au/ezyedit/fileLib/Catalogues/general3.pdf
It basically has two 3-way valves :
- Fuel from 1 of 2 tanks in ==> LP pump ==> swirl pot
- Return from swirl pot ==> 1 of 2 return ports to tanks
The following pic shows my fuel system setup
Hope this helps.
Kind Regards,
Peter D.
