Jim Rosenthal
I have been at building this car so damn long that I am probably repeating questions I posted years ago (this is what happens when you get old, and when you take nine years and counting to finish a project like my GT40), only this time I am asking these questions because we are actually DOING this stuff, so forgive me if, like a lot of old folks, I repeat myself:
Today we installed the pipes and hoses which connect the cooling system- the water pump to the main coolant tubes, and the main coolant tubes to the radiator. I also have the overflow tank, which will install on the engine room bulkhead on the starboard side. It hass a neck for a radiator-type cap, and also three NPT or some kind of threaded holes in the inner side. My car does not have a heater. There are also two short stub pipes coming out of the Ford water pump. One of them would ordinarily be used for a thermostat bypass, like on my 289 Cobra's 302 engine, but the bypass into the manifold is blocked off- the casting is not drilled for it.
So, it seems to me that we will have to drill a couple of bypass holes in the thermostat itself, first off. But the real purpose of this thread is to ask about how to do all the cooling system plumbing. The engine and the radiator which cools it are at opposite and high ends of the system- the transfer pipes are in the middle and they enter the radiator at the bottom of it. There are also two threaded holes in the radiator top tank which I assume are for bleed hoses.
The questions are:
-where do the air bleed lines run, and how are they hooked up?
-how do I fill the system? (we are thinking fill the engine manually first off, and then everything else, and install petcocks to permit us to burp the air out of the radiator at least)
-how do I ensure that all the dissolved air, once it coalesces into bubbles, can get to a high point in the system, specifically the overflow tank?
I would appreciate it if you all would share your experiences and advice. We are actually getting close to a point where we could put water and oil in the car and fire it up. (well, we'd still have to wire it, wouldn't we) and I would like to do this right the first time if I can.
By the way, the coolant tubes were made by Safir GT40. They are stainless steel, I think 316L, beaded at the ends for hoses and clamps, and they fit very nicely. (everything that was made by Brady Pack at Safir has fit the first time out, I am happy to report) We used silicone hoses and double-clamped some of the ends. The hoses were wrapped with exhaust pipe wrapping and over that high-temp heat shrink tubing was applied, which we hope will keep the heat inside the tunnel pipes and not radiate it all into the occupants of the car.
The questions are:
