Any suggestions as to wiring a one wire(single load wire, self fielding internal regulating) alternator to a dash voltage light? There is no threaded post to draw off the field windings on the case.
I'll keep my eye on this thread to see what outcome is.
Yes I have, just this morning. The relay triggers at a far lower voltage than I expected (and the spec sheet describes), so with the 11V zener it basically tells you when the voltage has dropped below 11. Too low; that just means the battery's dead.Alan,
Have you made any headway on your Voltage light creation? The anticipation is killing me!
Very cool, keep me posted!
Allen, I have finally gotten around to soldering this rig together. I am planning to use the alt+ as my 12 volt switched source. It is a convenient location(near the dash light wire and source+). Can these componants handle direct 100 amp alternator output or will it cook them? I am planning to silicone the board into a plastic box and mount it away from any heat source. I will keep you posted on its performance. Thanks
Here's a diagram of the relay with zener diode idea. The way I've laid it out it assumes that grounding the lead to the dash ALT light turns it on (which is how my SPF is wired for a 3-wire alternator), so it should work in your case. If that's not how your car is wired let me know.
In terms of physical construction you could solder the zener diode between pins 8 and 3. Then all you need to do is connect switched 12V to pin 1 (switched because this thing draws about 100 mA all the time so it would eventually drain your battery). Connect pin 3 to ground and pin 2 to the wire to your ALT light. You could foam tape the relay upside wherever is convenient, presumably in back of the dash near the ALT light, or you could put it back near the alternator where the ALT light wire presumably shows up; then you just need a switched 12V wire back there.
Having said all that, I ordered the parts for this and will test it when they arrive in a few days. I hope you can wait that long so I don't end up sending you on a wild goose chase, in case there's something wrong with the idea.
