Go Back   GT40s.com > GT40 Technical Forums > GT40 Tech - Fueling, Electrics, & Engine Cooling
GT40 Tech - Fueling, Electrics, & Engine Cooling Petrol, Electrons, & Water
Old 29th July 2012, 12:10 PM   #1 (permalink)
Brett James-McCall Moderator
brettmcc's Avatar
brettmcc
I Have No Life
GT40: RSGTD
Alternator wiring
Chaps,
Need some help for my simple brain. SOmeone got me this alternator years ago and I am now strating to try and wire the car up.
I am using a SGT loom and for the alternator part it says
Brown (16mm) > Starter Solenoid
Brown/Yellow > Dash Connector - IGN Warning Light
I am assuming the 16mm goes to the Red/Batt terminal below.
Where does the other go, or does the loom assume a 1 wire connection and I have another type of alternator?
IMAG0223 by Brett-GT40, on Flickr
Southern RSGTD; Mexican block; Audi 01X
I love the company so much I work for them and build them in my spare time....
brettmcc is offline
Old 29th July 2012, 03:39 PM   #2 (permalink)
PDub's Avatar
PDub
8 Tenths
GT40: Tornado
Re: Alternator wiring
You need the separate regulator to go with that alternator - less than £20 as I remember.
Best regards,
P.
Black Tornado TS40 a.k.a. "Black Beauty"
SBF 306 / Edelbrock pack / R21-Turbo box / Quaife LSD
17" BRM Pindrives / Roll cage / Hi-Spec brakes
PDub is offline
Old 29th July 2012, 04:54 PM   #3 (permalink)
3 Tenths
GT40: New Britain, CT
The diagram for the dash light alternator is appropriate.
Alternator/Regulator troubleshooting
Bob P.
Bob Putnam is offline
Old 30th July 2012, 06:07 AM   #4 (permalink)
stephentonks
France
GT40: Dax
Hi
I used to have an alternator off a mustang, or such like. Also had a voltage regulator. Wasn't really very good. I have since fitted an alternator off a Ford Ka, and done away with my regulator. Much better charging now.
Stephen
stephentonks is offline
Old 30th July 2012, 05:28 PM   #5 (permalink)
blueovalz's Avatar
blueovalz
Silver Supporter
Not for everybody, but I've had a lot of success with a single-wire alternatora, and plan on using another for this project.
Terry
Terry
blueovalz is offline
Similar Threads
Wiring 3G Alternator Igofaster Superformance GT40s 12 15th July 2012 08:08 PM
Alternator wiring - Ford 2G, advice required Julian West GT40 Tech - Fueling, Electrics, & Engine Cooling 18 22nd April 2010 01:58 PM
Alternator bracket and alternator wanted simonjrwinter GT40s Wanted, and Parts or Services Needed 1 31st January 2010 08:26 PM
Alternator wiring G Gear GT40 Tech - Fueling, Electrics, & Engine Cooling 2 30th December 2006 11:45 AM
One Wire Alternator Wiring Ron Earp GT40 Tech - Chassis,Brakes,Tires,&Wheels 6 4th July 2005 12:42 PM
