Chris Kouba
Last I drove it about 2 weeks ago, I noticed a little bit of backfire which I (probably wrongly) attributed to air in the EFI high pressure loop. Tonight I took it out for a little spin and needed a tow home.
Car started and idled normally out of the shop. My run begins with a downhill leg of about a mile. There is a stop sign after 1/4 mi, and I negotiated this without issue. Car was running normally, or so I thought, but it was idling downhill to get there. It pulled away fine from the stop but I wasn't hard on it either as it was still not warmed up yet.
The next 1/2+ mile was downhill to another stop sign. I got up to speed casually from the stop and coasted the entire way down the hill to the next one. When I dumped the clutch to start braking and rowing gears, there was no motivation from the motor. I rolled across the intx and tried cranking it on the other side... No dice.
Got it home, confirmed no spark. I do have voltage to the coil. How do I test it? It's an Edelbrock Pro-Flo (first gen) with an MSD dist and coil.
Any other suggestions?
Thanks in advance!
Chris
Thanks in advance!
Chris
