Here are a couple pics of my mocked up system without the connecting hoses.
The intake line will come up from the tank (see place where black tape is covering the access area now) then go down to the low pressure Holley sitting on the lower level. It in turn will push fuel through a 75 micron filter (Fuelab suggested pushing instead of pulling as the Holley has a built in screen and low pressure pumps don't like to work too hard to suck fuel...less obstruction this way). That will exit out and go back on top to feed the swirl pot. That in turn feeds the high pressure pump which exits into a 10 micron filter then onto the rails. The regulator will be mounted on the back bulkhead just above the engine. I will also hok up the overfill return from the swirl to the main tank (spilling onto foam...guess that is OK although it might wear down the foam at that spot in time).
Please let me know if you see anything you don't like about this setup.
Thanks.
Thanks.
