Hi can anybody help, I need to remove the fuel tank from my CAV number 117. I did not build the car and as far as I can work it out I must have to remove the front suspension and disconnect the fuel lines, filler hose and the level gauge, will it then pull out forward or is it bolted or clamped in position if so where is it fixed.
Or I could be completely wrong
