Daisy chain radiator bleed lines?
If i have 2 radiators, one on each side of the car, can I daisy chain the bleed lines together? (i.e., go from 1 rad to the other, then at that rad T it and take it to a high point in my expansion tank)
I'm pretty sure i can because what's the difference between daisy chaining 2 rads together versus if I had 1 rad with 2 bleed ports and i daisy changed the 2 ports together?
i can run 2 lines, one for each radiator, but that would be a bit cluttered and daisy chaining them would be nicer, if that's okay to do.
Fran Hall RCR
GT40s Sponsor
You will be potentially pushing any air from one rad to another.
I would run individual ones and tee them together further down the line returning to the coolant reservoir.
That was my concern and what I've heard from others, so I guess I'll just run 2 separate lines.
Btw, I've got 3 rads now .... we've been busy .... most sacrilegious 917 will soon be the most awesomest sacrilegious 917 eva :D
