Cooling capacity
A quick question. I run a Tornado TS40 fitted with 302 engine, standard radiator/piping (with aircon)
Could someone just confirm the capacity of the entire cooling system in litres.
Many thanks.
John it'll depend on what various components are on your car - I'd guess its about 12 litres total, use 50/50 water/antifreeze.
My RCR takes 13 litres of 50/50 water/red anti freeze. Despite a rad bleed pipe to the fill tank it can take a while to bleed the final litre into the system so keep checking the level.
Roger
Hi John, if the ratio is 50/50, then simply put a litre of antifreeze in, then a litre of water, then a litre of antifreeze, then a litre of water and keep going until the system is ful and all air is out of the system. Then you'll know for certain what capacity your system is, assuming you don't lose count! Best Regards, Andrew
