Heater......
Hi guys and girls . The heater supplied with the kit has 4 wires on it . red ,,,,yellow...orange ... black ........ on my loom there are 2 wires green with yellow trace ... and the other is 2 light green wires connected together .. don't matter what ones I connect . the fan wont run unless I put the black wire to ground . But then It wont turn off ???any ideas what the best way to wire it up ...
Thanks all John..
My kit is a Tornado...
Hi John,
The wires on the fan motor are most likely:
<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com
FONT><BR><FONT size=3><FONT face=Calibri>Fast Speed – <
<st1:place w:st="on">Orange </st1:place>
<st1:place w:st="on"></st1:place><o:p></o:p>
The switch should have then a 12V input feed. Using a test meter, you should be able to work out how the pins work and then what colour wires are used in your harness<o:p></o:p>
Hope this helps<o:p></o:p>
Regards,<o:p></o:p>
Andy<o:p></o:p>
Hi Andy m8 .I ordered a 3 speed fan switch before I went on holiday . So I had a go yesterday .. Bit of testing and fiddling ............. and I now have a 3 speed working heater fan and switch .. Thanks for your input as always m8 ..
John..
