Go Back   GT40s.com > >
GT40 Tech - Fueling, Electrics, & Engine Cooling Petrol, Electrons, & Water
Thread Tools Display Modes
Old 20th October 2017, 10:46 AM   #1
tomgayer's Avatar
tomgayer
GT40: scratchbuilt
Radiator Questions
in the photo i have a radiator exactly like this one . i need to know what the large red screw on the right side is for and the small red screw on the top left and if it matters which side is hot and which is cold on the hoses.
thanks
tom
Radiator Questions-gt40correctradiator-jpg
tomgayer is offline   Reply With Quote
Old 20th October 2017, 11:39 AM   #2
IanAnderson's Avatar
IanAnderson
GT40: Dax 40 Mk1 (Rov
Re: Radiator Questions
Small hole at top is a bleed pipe back to the header tank
Large hole is for the fan switch - It is called an otter switch
Inlet would be on the left side of that photograph and outlet on the right
DAX GT40. Morgan 3.9 EFi, Worked by John Eales.
IanAnderson is offline   Reply With Quote
Old 20th October 2017, 11:54 AM   #3
tomgayer's Avatar
tomgayer
GT40: scratchbuilt
thank you Ian, that helps a lot
tom
Old 25th January 2018, 07:37 AM   #4
tomgayer's Avatar
tomgayer
GT40: scratchbuilt
Good morning England,
I had a few questions with my radiator Ian, since I am running a reverse rotation water pump and my otter switch connection is on the left side of the radiator (driver side in America). i uploaded a photo of the actual radiator.
Old 24th March 2018, 11:35 PM   #5
bill kearley
Canada
GT40: CAV 193
It all works the same but would it not be better to have the fan switch at the water outlet on the intake, twill turn the fan on a little sooner. I was going to put mine at the rad as well but not to shr yet. what do others think?
bill kearley is offline   Reply With Quote
Tags
left, radiator, red, screw, side
Forum Jump
