Go Back   GT40s.com > GT40 Technical Forums > GT40 Tech - Fueling and Electrics
GT40 Tech - Fueling and Electrics Petrol and Electrons.
Old 10-28-07, 03:51 PM   #1 (permalink)
GT40: New Zealand
Rep Power: 8 brianstewart will become famous soon enough
Stewart Warner pumps
I have just acquired two original 240-A SW fuel pumps. One has the little rubber cap on the top (over the pressure regulating nut) split, the other has it missing. What function do these caps serve and how essential are they? Anyone know of a source of new ones if they are needed?
Thanks,
Brian.
Classic Car Developments
Scratch built monocoque
351W
ZF
brianstewart is offline
Old 10-29-07, 03:55 PM   #2 (permalink)
Doc Watson's Avatar
Doc Watson
5 Tenths
GT40: Replica Mk I
Re: Stewart Warner pumps
Not sure about a source for new ones (I could do with 2 myself!!) but I do have the original service manual for the pumps.
The manual states that the assembly at the top is part of the pressure regulator. It also states that the rubber end piece is a 'pulse chamber' although I cannot see any reference to it in the manuals.
Hope this in some way helps
Andy
replica mono chassis
original rear clip
1966 289
48IDA's
This month its going to be red
'This car you have to be measured for...'
Doc Watson is offline
Old 10-29-07, 04:28 PM   #3 (permalink)
GT40: New Zealand
Thanks Andy - looks like it is needed.
351W
ZF
Old 10-29-07, 07:07 PM   #4 (permalink)
Big-Foot's Avatar
Big-Foot
Gold Supporter
GT40: Replica
Rep Power: 18 Big-Foot has a brilliant futureBig-Foot has a brilliant futureBig-Foot has a brilliant future
I always thought that the cap only protected the threads on the regulator screw.. Hmmm...
Andy - do you have any other exploded diagrams of these pumps?
Regards - Randy
Big-Foot is offline
Old 10-29-07, 08:08 PM   #5 (permalink)
Jimmy M's Avatar
Jimmy M
GT40: DRB #62
Rep Power: 4 Jimmy M is on a distinguished road
Only guessing but I would think the 'pulse chamber' covers the opening and allows air movement when the diaphram moves while regulating pressure.
You could probably just put some sort of filter on/in it if you cant get originals.
Just an observation, I may be completely out of left field........
JM
Jimmy M is offline
Old 10-31-07, 04:11 AM   #6 (permalink)
Doc Watson's Avatar
Doc Watson
5 Tenths
GT40: Replica Mk I
Randy,
Yes I do have more exploded diagrams of the pumps, send me a PM and I will email them to you.
Andy
original rear clip
1966 289
48IDA's
Old 10-31-07, 08:43 AM   #7 (permalink)
nota2266's Avatar
nota2266
GT40: Kurrajong, Australia
I have run SW pumps with and without the rubber cap. It does not make any difference to its operation but I would suggest that if you had a solid rubber plug it would build up pressure in the upper chamber and may well affect the operation of the pump.
Trevor Booth,
Finished assembling a pile of bits incl, mono, 302W on IDF's,ZF, 15" pin drive BRM.
nota2266 is offline
Old 10-31-07, 06:48 PM   #8 (permalink)
toy264's Avatar
toy264
Rep Power: 5 toy264 will become famous soon enough
Is the regulator on the SW pump good enough to run without a second regulator in the line, or should it be run wide open and regulated closer to the carbs?
John
toy264 is offline
Old 11-01-07, 07:11 AM   #9 (permalink)
nota2266's Avatar
nota2266
If you look carefully at some of the original car photos they did use a secondary regulator /filter unit. I have not found a need for this and use the SW regulator without any issues cranking 470HP on Webers.
What you do need to do is be very precise setting the pressure on both pumps exactly the same, this is the reason I believe they used a single regulator. If they had to replace a pump in a long distance race they would not need to worry about setting the pressure. When setting the pressure do not rely on a gauge, I use a piece of plastic tube taped to a graduated board and held near vertical at the carburettor fuel inlet and with the zero graduation at the same height as the fule inlet.
the height that the pump sends the fuel up the tube is then read off the graduated board. The height in feet X 0.434 = psi.
Trevor Booth,
nota2266 is offline
