Go Back   GT40s.com > GT40 Technical Forums > GT40 Tech - Fueling and Electrics
GT40 Tech - Fueling and Electrics Petrol and Electrons.
Old 12-30-07, 12:32 AM   #1 (permalink)
Big-Foot's Avatar
Big-Foot
Gold Supporter
GT40: Replica
Rep Power: 17 Big-Foot has a brilliant futureBig-Foot has a brilliant futureBig-Foot has a brilliant future
Fuel Tank crossover / equalizer
Curious if anyone has successfully implemented a crossover system to keep the fuel load equalized between the two tanks on a GT40..
I was thinking (dangerous - I know) that it would be a PITB to have to hold the fuel filling hose at the service station over the top of the car to fill the tank on the opposite side. Also curious how it was done on some of the Gulf cars I've seen with only a single fuel filler..
Thanks guys...
Regards - Randy
Big-Foot is online now
Old 12-30-07, 01:06 AM   #2 (permalink)
Jim Sheren's Avatar
Jim Sheren
GT40: RCR someday
Rep Power: 4 Jim Sheren has a spectacular aura about
Re: Fuel Tank crossover / equalizer
Randy,
Could you weld threaded bungs into each tank close to where the tanks are welded to the fire wall behind the seats?? I know this sounds scary, but you could use a re-enforced type rubber hose, kind of like hydraulic hose to connect the two tanks, then take 1/8" wall aluminum tubing and cut a 1/4 of it away and then build a shield around it. So the line would be down in the bottom coner behind your butt, then the shield looks like a fillet going around it. I would assume it could go through the tunnel for the radiator cooling tubes and not take up too much space?
Maybe this is just crazy. Without looking at it and seeing the packaging it's hard to say.
I know Fran is probably cringing, Sorry in advance Fran
Maybe Fran could offer this; wink, wink Or maybe not.
Jim S.
GT40 Dreaming
Jim Sheren is offline
Old 12-30-07, 01:16 AM   #3 (permalink)
Jim C's Avatar
Jim C
4 Tenths
GT40: RF 105
Rep Power: 8 Jim C will become famous soon enough
Yes
all I have done and others have done the same. A pipe 3/4 to 1" between tanks.
Mine runs from the rear of the tanks across the bottom of the rear bulk head(firewall)at floor level.
Im still running 2 filler caps but have gone to 1 fuel sender.
Jim
Occupation Automotive
Interests are
Fabrication and design
Building my car
Sydney Australia
www.mentalperformance.com.au
Jim C is offline
Old 12-30-07, 02:02 AM   #4 (permalink)
jac mac's Avatar
jac mac
Rep Power: 18 jac mac has much to be proud ofjac mac has much to be proud of
I'm planning on running a tube or hose thru an alloy tube under the front of the seat area. The lower part of the seat being a fixed metal piece as per the originals & to be welded into the structure. I feel this is about the safest area in the car and dont like the idea of tubes/hoses in the proximity of the front damper etc where if damage was to occur it wont be easily spotted.
jac mac is offline
Old 12-30-07, 04:06 AM   #5 (permalink)
Russ Noble's Avatar
Russ Noble
GT40: Building scratc
Rep Power: 19 Russ Noble has much to be proud ofRuss Noble has much to be proud of
I'm planning on keeping mine seperate. Twin fillers don't seem to be a problem. Lots of Jags use them. I know the XJ's had twin fillers and I'm sure from years gone by that my old Mk VIII 3.4 MOD had them also.
If you want it to equalise quickly while you're filling I think you'll need more than a 1'' crossover. I think I read somewhere that the Gulf cars had a 2'' or 2 and a half inch crossover.
Cheers,
Russ
Russ Noble is offline
Old 12-30-07, 08:21 AM   #6 (permalink)
delaneyp's Avatar
delaneyp
Peter D
GT40: DRB #27
Rep Power: 20 delaneyp is a splendid one to behold
Randy, for what its worth, I have separate tanks/fillers & a change-over valve - never had a problem filling up 2 tanks as the car is so low that the petrol station hose is easily taken around the front from one side to the other (also provides a talking point for the gawkers, etc) !!
If you join the 2 tanks & want to fill from one side, you will need at least a 1" crossover pipe (as Russ mentioned). IMHO, the less fuel piping (and the smaller it is) is a safer prospect - the thought of a 1" or 2" crossover pipe at the bottom of the tanks letting go is not a nice thought !
I have a separate fuel sender & gauge for each tank - given the long / shallow tanks, these are rudimentary at best : you get a bit of an idea of what's there on the level, but most of the time they act as inclinometers ! If they read full, you are going up / if they read empty, you are going down !!
Kind Regards,
Peter D.
DRB (GT40 Australia) #27
331 Windsor / GD-50
8-Stack EFI / Autronic
Dark Metallic Blue Pearl
delaneyp is offline
Old 12-30-07, 08:36 AM   #7 (permalink)
IanAnderson's Avatar
IanAnderson
Gold Supporter
GT40: Dax 40 Mk1 (Rover3.9EFi)
Rep Power: 17 IanAnderson is a jewel in the rough
With the big cross over pipe don't forget to run an air bleed pipe too or when you fill the tanks the one without the filler is going to not fill to well with a bib "air bubble" above the fue;l level
Also suggestion if you go this route make the working cap opposite to your driving seat - it will save problems when you pull up to the pump and cannot open your door as you are too close to the pump (yes I did it once)
IanAnderson is offline
Old 12-30-07, 09:41 AM   #8 (permalink)
Big-Foot's Avatar
Big-Foot
Gold Supporter
GT40: Replica
Great responses guys.... Thanks for your input! Yes I have thought of running the crossover pipe through the interior just aft of the seats but my issue is in how to get the pipe through the tunnel without taking up too much space. I had thought of using rectangular tubing that would lay flat - but I would need to weld it in place (not the end of the world) to maintain the integrity of the tub.. So my next thoughts were to actually place the crossover in the engine bay yet protect it well from debris... Not certain just how yet... Still examining alternatives.. I'll try to get a picture of the bay uploaded here later..
Good point - There are breather tubes right next to the fill tubes on the RCR.
Ian - you hit the nail on the head directly... This was the first thing that triggered my entire train of thought on the subject...
Regards - Randy
Old 12-30-07, 10:25 AM   #9 (permalink)
dlindemann's Avatar
dlindemann
GT40: SLC on order!
Rep Power: 3 dlindemann is on a distinguished road
Hi Randy -
Lotus Esprits have dual tanks and cross-over pipes. My S1 has a very small diameter cross-over of about 5/16" and it is too small to be effective - I still have to fill both tanks. The cross-over consists of a steel tube running across the engine bay with fuel hose connections to each tank. Later Esprits utilized a larger diameter cross-over pipe. I'm not sure of the exact size but it is an inch or less in diameter. This allows filling from one side with venting provided by removing the filler cap on the opposite side. Not sure I'd want to run a fuel line through the interior of the car - just my $.02.
Dave L
dlindemann is offline
Old 12-30-07, 10:47 AM   #10 (permalink)
Andy Sheldon's Avatar
Andy Sheldon
Sponsoring Vendor
GT40: Tornado TS40
Rep Power: 10 Andy Sheldon is a splendid one to behold
Big Foot
We have linked tanks to use a single filler on a few cars fully built for customers.
We used 1 1/2" diameter link pipe. It needs to be large enough so that it can flow into the second tank as quick as the first is filled by the petrol pump at the filler station.
Andy
Andy Sheldon
TORNADO SPORTS CARS
www.tornadosportscars.com
Andy Sheldon is offline
Old 12-30-07, 03:55 PM   #11 (permalink)
wbmusarra's Avatar
wbmusarra
Location: Snellville, Ga. "Everybody's somebody in Snellville"
GT40: DRB#5
Rep Power: 19 wbmusarra is a name known to all
When laying out my concerns for the fuel lines, I made the decision to use one set of pumps. The cost of the AN fittings and the pumps were getting rather expensive. Since I have Fuel injection, my concerns centered around the flow of the fuel. What I came up with is very simple. The uptake to the pumps is from rear of the passenger side(LHD). Once the circuit for the fuel leaves the injectors, it flows back to the surge tank. The overflow then is routed to the drivers side tank. The two tanks will be connected via AN lines(size not determined yet). The pan of the DRBs is corregated and the line will be secured to that on the outside. I have a fear of leaking fuel in the cabin. The fill pipes are enough to worry about. The line connecting the two tanks will have a flapper valve(no resistance to flow), with the flow directed to the passenger side. Both tanks will be vented and rollover protected. The fuel guage will use a non moving sender, so I will have an accurate measure of reserve.
DRB#5
351 Windsor bored, stroked internaly balanced
DIS
TWM 8 Port F. I.
930 Porsche LSD
wbmusarra is offline
Old 12-30-07, 10:17 PM   #12 (permalink)
Cobraownr's Avatar
Cobraownr
Silver Supporter
GT40: Original 1966 M
Rep Power: 7 Cobraownr has a spectacular aura about
Thanks guys...
A number of original Mk I GT40s had a fuel crossover pipe and just one filler cap. Six independent Mk Is (including my P1040) that were prepared by FAV for 1966 Le Mans had this feature. The crossover pipe in my car runs from right to left just in front of the seats. However, this may not be the original spec, as I know my tanks are not original. A few of the later Mk Is also had fuel crossovers, and some (and maybe all) Mk IIs.
29 years with original GT40 #P1040
--and 25 years that it's been apart!
Cobraownr is offline
Old 12-30-07, 11:50 PM   #13 (permalink)
prre's Avatar
prre
Silver Supporter
GT40: GT40 Developments Chassis, Tornado Bodied
Rep Power: 7 prre is on a distinguished road
Bill what type of non moving sender unit are you going to use?
Paul R
Tornado Bodied GT40 Developments Chassis
prre is offline
Old 12-31-07, 10:32 AM   #14 (permalink)
wbmusarra's Avatar
wbmusarra
GT40: DRB#5
Paul,
Racer Parts Wholesale has the Fuel Safe one. Not sure if that is the one I have, but it works the same. You have to supply the Ohms, and they will ship it. I have a Stewart Warner gauge and it works very nicely. My car isn't at home right now or I would send some pics. It should be here in the next day or two. Exhaust is being fabed at present.The unit can be shortened to 3 1/2" if need be. Mine has the same features as theirs I believe. It should have a low level sensor that is adjustable and can be wired to turn on a warning light. If it doesn't then mine is different and I will send you the info when the car gets home. The full point is adjustable as well. Not exactly cheap, but it is nice to have a reminder that the tank is getting low. If this isn't the page just scroll down near the end of the catalog.
http://www.racerpartswholesale.com/d...%20Catalog.pdf
DRB#5
DIS
TWM 8 Port F. I.
930 Porsche LSD
Old 12-31-07, 12:04 PM   #15 (permalink)
prre's Avatar
prre
Silver Supporter
Thnaks Bill for the info I will check it out.
Paul R
prre is offline
Old 01-01-08, 11:30 AM   #16 (permalink)
wbmusarra's Avatar
wbmusarra
GT40: DRB#5
Pegasus Auto Racing has the full description and is a few bucks cheaper.
Pegasus - Fuel Level Gauge for Fuel Cells, 0-90 Ohm
They also have the 240-33 Ohm unit as well.
DRB#5
DIS
TWM 8 Port F. I.
930 Porsche LSD
Old 01-10-08, 01:31 AM   #17 (permalink)
Dee
v8goat's Avatar
v8goat
Rep Power: 1 v8goat is on a distinguished road
Hi Bill,
I have always run the injector return back to the main tank, as I had heard that if it runs back to the surge tank that it can go round and round from surge tank to injector rail back to surge tank to injector rail etc, heating up a little each time it travels the injector rail (from heat of engine).
v8goat is offline
Old 01-10-08, 02:42 PM   #18 (permalink)
IanAnderson
Gold Supporter
Dee
A lot of discussion on this in the past
Go downhill on 1/2 tanks with the return to the main tank and you are likely to pump all the fuel out the surge / swirl post very quickly
Even a Facit red top will pump about 3 litres per minute - how big is your swirl tank to avoid sucking air?
Old 01-12-08, 04:55 PM   #19 (permalink)
Dee
v8goat's Avatar
