how to jack up
Ian Clark
The car can be safely supported on jack stands. We put wooden plates or 2x4 lumber across the stands to spread the load. The area under the transaxle hoop and the end of the chassis just in front of the pedals are your best bet. Do not lift the car from the rad sub frame, the rear body subframe or the sills.
are there no clear points on the car to lift it?
so you better inform lets say the garage very clear were to and were not to lift it? otherwise when you are not there they just lift it with lets say a 4 point lift...:shocked:
