Old 12-05-05, 03:22 PM   #1 (permalink)
daveharris
3 Tenths
GT40: Northern Ca,
Rep Power: 10 daveharris is on a distinguished road
DRB Flywheels - - what balance from the factory
Does anyone know if the standard flywheel (for a 302) comes as zero balanced or with the weights on? Getting ready to send out the rotating assy and I'm not sure what I'm starting with!!
daveharris is offline
Old 12-05-05, 04:19 PM   #2 (permalink)
flatchat's Avatar
flatchat
Silver Supporter
Re: DRB Flywheels - - what balance from the factory
If it's for the G50/Porsche clutch and it's a windsor motor with a 28oz or a 50oz counterweight .
At the very least it needs to be match balanced with the original flywheel that came with the motor--would recommend a full rotational assy. balance incl.clutch.
Flywheel should look something like this to start with [img]/ubbthreads/images/graemlins/twocents.gif[/img]
flatchat is offline
Old 12-05-05, 11:28 PM   #3 (permalink)
daveharris
3 Tenths
GT40: Northern Ca,
Thanks Flatchat - - I was hoping that the flywheel came "zero balanced" as I'd like to get the engine internally balanced, but I'm not sure it will be possible with the original 289 crank - and I was hoping not to have to go to the 302 stroke length in the motor (want to turn some revs!).
Does anyone know of an aftermarket crank maker who still makes 289 cranks (forged)?
thanks again
Old 12-06-05, 12:55 AM   #4 (permalink)
flatchat's Avatar
flatchat
Silver Supporter
The Flywheel can be supplied zero balanced (ie no counterweight machining) no problems [img]/ubbthreads/images/graemlins/beerchug.gif[/img]
flatchat is offline
Old 05-26-06, 03:19 AM   #5 (permalink)
New Zealand
Rep Power: 3 sp250 is on a distinguished road
flat chat
re the ls1 to g50 adaptor. whats the story with the release system? in this case have the smaller shaft size - 15 / 16 mm. no arm or shaft supplied. can you give me a current figure on your conversion kit please. what clutch is it set up for ? thanks. steve
sp250 is offline
Old 05-26-06, 08:41 AM   #6 (permalink)
Mark Worthington's Avatar
Mark Worthington
GT40: Massachusetts
Yes. Crower.
Mark
347, MoTeC EFI, pin drives, leather, etc.
Mark Worthington is offline
Old 05-29-06, 07:22 PM   #7 (permalink)
New Zealand
g50
hi flatchat, that inqiry is genuine. need price and info on kit. thanks steve
sp250 is offline
