Old 09-17-06, 04:21 AM   #1 (permalink)
jac mac's Avatar
jac mac
New Zealand
Rep Power: 23 jac mac has much to be proud ofjac mac has much to be proud of
Question ZF Dimensions
Does anyone have a ZF out of a car at the moment that could measure accurately the diameter of the register on the front face of the T/Axle or the rear face of the Bell Housing. This is the stepped register that pass's thru the four bolt holes that attach Trans to Bellhousing.
Thankyou.
Jac Mac.
jac mac is offline
Old 09-17-06, 06:33 AM   #2 (permalink)
JIMMYMAC
Rep Power: 17 JIMMYMAC has much to be proud ofJIMMYMAC has much to be proud of
Re: ZF Dimensions
[/quote]This is the stepped register that pass's thru the four bolt holes that attach Trans to Bellhousing.[/quote]
Jac Mac
I will try to help but I'm confused with your "four bolt" statement.
Below is a bell where I have just measured the inner counterbored register diameter as 275.46mm with good verniers.
If you need any other dimensions from it just send me a pm.
I will also try to get the data verified by the ZF professional I know for you.
Name:	ZF Bellhousing 06.jpg
Cordially,
James
Graviner Fire Suppression
JIMMYMAC is online now
Old 09-17-06, 06:48 AM   #3 (permalink)
roy snook's Avatar
roy snook
3 Tenths
GT40: FAV Monocoque
Rep Power: 11 roy snook has a spectacular aura about
Re: ZF Dimensions
Hi Jac Mac,
I have a four bolt ZF-0, out of my car at the moment, I will mail a picture and measuremnts to you.
Assembling Own Pressed Panel Monocoque. Original Front Clip, -0 ZF, 66-289 IDA's
roy snook is offline
Old 09-17-06, 06:52 AM   #4 (permalink)
JIMMYMAC
Re: ZF Dimensions
Roy,
Thanks for that clarification - This bell was for a ZF2
Cordially,
James
Old 09-17-06, 06:54 AM   #5 (permalink)
roy snook's Avatar
roy snook
3 Tenths
GT40: FAV Monocoque
Re: ZF Dimensions
Hi JimmyMac,
the bellhousing in your picture is for the later -2 box, the early boxes were 4 bolt to bellhousing.
Old 09-18-06, 05:35 AM   #6 (permalink)
ross nicol's Avatar
ross nicol
Rep Power: 21 ross nicol has a brilliant futureross nicol has a brilliant futureross nicol has a brilliant future
Re: ZF Dimensions
Hi Jac Mac
I'm fiddling with ZF/2 bellhousings at the moment. The face of the box is roughly 175mm. I can get you any specs for this box as it's on my work bench at the moment. I'm actually making a plastic template for the bell housings to be machined.
Ross
RF #025 currently racing
ZF,Motec injection
Lotus Europa S2
De Tomaso Pantera
ross nicol is offline
Old 09-18-06, 06:42 AM   #7 (permalink)
jac mac's Avatar
jac mac
New Zealand
Re: ZF Dimensions
Hi Ross,
JimmyMac has given me the dimension for -2 recess dia as above in post# 2 and Roy is going to fwd the same dimension off a -0. Only other dimension I will require is length of bellhousing-[rear face of motor to front face of T/Axle ]. These two dimensions will be enough to get me on the way. Just want to make sure I put enough material in the casting to cover either trans option.
Jac Mac
jac mac is offline
Old 09-18-06, 03:36 PM   #8 (permalink)
JIMMYMAC
Re: ZF Dimensions
Jac Mac,
This one is 100mm long face to face.
The worktop is pretty level and I don't have my machinist's table so I took six datums.
I double checked the vernier height on a glass table afterward with a Rabone Chesterman rule.
Name:	BELLHOUSING LENGTH.jpg
Cordially,
James
Old 09-18-06, 04:22 PM   #9 (permalink)
jac mac's Avatar
jac mac
New Zealand
Re: ZF Dimensions
Thanks very much James,
You will do well in the race car scene with measurements like these.
Just one offtopic comment, you will need measuring equipment capable of larger dimensions when you catch some trout out here!!
Jac Mac
jac mac is offline
Old 09-18-06, 09:19 PM   #10 (permalink)
ross nicol's Avatar
ross nicol
Re: ZF Dimensions
I haven't got James' fancy measuring equipment but I can confirm the 100mm face to face measurement. I'll be in sunny Southland next week Jac Mac but won't have time to go fishing.
Ross
ZF,Motec injection
Lotus Europa S2
De Tomaso Pantera
Old 09-19-06, 12:10 AM   #11 (permalink)
jac mac's Avatar
jac mac
New Zealand
Re: ZF Dimensions
I hear the WhiteBait are running Ross, maybe someone will give you a taste!!
Dont ask me, all I have had so far is promise's.
Thanks for checking the dimension, now all I need is some get up & go to make the thing!
Jac Mac
jac mac is offline
Old 09-19-06, 03:51 PM   #12 (permalink)
JIMMYMAC
Re: ZF Dimensions
Jac Mac / Russ,
I had this nice little trout for your barbie. Unfortunately for you, it went back into the river, as they all do in New Zealand for conservation reasons.
Maybe that is why you have to eat whitebait instead ?
Cordially,
James
Old 09-19-06, 04:03 PM   #13 (permalink)
Russ Noble's Avatar
Russ Noble
New Zealand
GT40: Building scratc
Cool Re: ZF Dimensions
Nothing wrong with whitebait once you've topped and tailed them JimmyMac!!!
Russ Noble is offline
Old 09-19-06, 04:40 PM   #14 (permalink)
JIMMYMAC
Re: ZF Dimensions
Hmm....... I understand now.
That's why you can get into a 40 and I have difficulty.
Stay alert, steady on the throttle and sharp into those bends. And even win.
Your on a micro diet !!!
But I hope you don't mind me saying so Russ, "it's a bit of a skinflint barbie mate"
Cordially,
James
Similar Threads
CAV, RF, RCR, ZF 5-speed cable shifters snoman_sd GT40 Parts For Sale 7 03-08-08 01:26 AM
Seat dimensions Paul Bearman GT40 Tech - Exterior, Interior, AC, & Trim 7 03-27-06 05:07 PM
Engine dimensions jkyle69 GT40 Tech - Engines/Induction/Exhaust 0 02-06-06 01:19 PM
Gearbox driveshaft dimensions John W GT40 Tech - Powertrain/Transaxles 4 06-14-05 04:34 AM
bolt pattern dimensions for G50/52?? mike_starling GT40 Tech - Engines/Induction/Exhaust 6 07-22-04 04:31 PM
