Hi Pat, John,
Thanks for the positive feedback on the shifter upgrade
Cliff,
On the Audi/Getrag we haven't got an upgrade for that system since all our cars have been ZFs. The Getrag cable system should do the job untill you're ready to make the jump to a ZF.
CAV Canada will be able to supply everything for the conversion except the transaxle, call Lloyd at RBT for that. The ZF Kit will include: Shifter, Shift Rods, Firewall Filler Panel with Support Bearing, Bellhousing, Transaxle Mounting Bracket, Clutch (single or twin disc), Aluminum Flywheel, Hydraulic Throwout Bearing, Hydraulic Lines and Fittings, HighTorque Starter and Starter Locating Plate.
Also when you go to the ZF your engine can drop to the original height, which will require new Motor Mounts and Oil Pan with Pickup. The stock Ford pans are 7.5 inches deep and the original style Aviad wet sump pans are 6.5. Again we can supply all these parts.
Enjoy your CAV GT and please feel free to call on the toll free tech line for a chat or assist you any way I can.
