Old 11-04-06, 12:56 AM   1 links from elsewhere to this Post. Click to view. #1 (permalink)
albanygt40's Avatar
albanygt40
3 Tenths
GT40: Albany west Aus
Rep Power: 7 albanygt40 is a jewel in the rough
Unhappy 016 KEP adapter kit
Hi Guys
I've fitted my KEP 016 to Windsor 5ltr adapter to my GT40 and am having
trouble with clutch, I have the stage 2 pressure plate. When I press the
clutch pedal it wont release the clutch plate. Now I've bleed the system
correctly and my slave cylinder is good condition (standard audi).
I started with a 5/8 master cylinder and got a good pedal but no actuation
at the box , I've just changed the master cylinder to a 3/4 and only just seem to get the clucth to release a small amount and can only just turn
the wheel with a great amount of force. Do I need to use a 1 inch master
or bigger size or have I gone wrong somewhere else?
FFR Coupe #385 5ltr T5 44IDF's LSD
albanygt40 is online now
Old 11-04-06, 08:18 AM   #2 (permalink)
Jim C's Avatar
Jim C
Gold Supporter
GT40: RF 105
Rep Power: 10 Jim C will become famous soon enough
Re: 016 KEP adapter kit
Dave it sounds like it may be somewere else.
I have used both those master cylinder sizes with no problem.
Ended up with the 5/8 as it gave a lighter pedal.
One thing I have had on several occations and always with cars with that have rear engines is trying to bleed it out.
I have had to use a vacuum bleeder.
The other thing is you are happy in that area then maybe the input shaft is pushing into the back of the crank ? worth a look.
Jim
Occupation Automotive
Interests are
Fabrication and design
Building my car
Sydney Australia
www.mentalperformance.com.au
Jim C is offline
Old 11-04-06, 09:21 AM   #3 (permalink)
albanygt40's Avatar
albanygt40
3 Tenths
Hi Jim
I've bleed the system several times and when you press the clutch
pedal it feels good and when i swapped to a 3/4 master cylinder after bleeding, the pedal felt heavier. I will check and see if the input shaft is hitting the back of the crank. I think it will come down something like that.
Hoping someone with a KEP kit will chime in.
Old 11-04-06, 12:47 PM   #4 (permalink)
Neal's Avatar
Neal
8 Tenths
GT40: GT40 NZ
Rep Power: 16 Neal is a glorious beacon of light
I used a 7/8" master without problems. Pedal feel is a bit heavy but not bad.
GT40 NZ - 347 / Webers / Red and White - My build site
FFR Roadster #4867 408 / TKO / 3-Link
Neal is offline
Old 11-05-06, 02:54 AM   #5 (permalink)
albanygt40's Avatar
albanygt40
3 Tenths
Talking Re: 016 KEP adapter kit
Jim "What a legend".
The input shaft was catching on the spigot bearing housing which
wasn't all the way home in the crankshaft, a couple of whacks with the hammer and all clears well and I have a clutch working with 5/8 master cylinder. Thanks Mate.
Old 11-05-06, 05:58 AM   #6 (permalink)
nanard289's Avatar
nanard289
France
Rep Power: 3 nanard289 will become famous soon enough
Originally Posted by albanygt40
Hi Guys
I started with a 5/8 master cylinder and got a good pedal but no actuation at the box , I've just changed the master cylinder to a 3/4 and only just seem to get the clucth to release a small amount and can only just turn the wheel with a great amount of force. Do I need to use a 1 inch master or bigger size or have I gone wrong somewhere else?
Hello Dave
5/8 and 3/4" clutch master cylinders are usual values to have the best relation between pedal travel, pedal effort and "progressivity" (note sure about this word ). However, we have to take car about the "pedal ratio" that is the distance between pedal axle and master cylinder rod connection. It means that if this ratio is shorter you have to use a large master cylinder that will work with a short travel. In opposite, if you have a large ratio, use a smaller master cylinder that will work with a longer travel. Basic principle is to obtain the righ oil volume displacement to move the slave cylinder accordingly. Second point is the clutch fork ratio. I don't know the AUDI value for your case but if it is a large ratio, you may have to use a larger master cylinder to compensate the requested long travel. Before to change your master cylinder for a larger one, you have to check first the mechanical gap between the slave cylinder and the cluch fork. It should be ajusted to have only a small "dead" travel (about 1/16") before clutch pushing action (you can feel it on the pedal effort when it become hard). Also, request to a friend to push slowly the clutch pedal and have a look on your slave cylinder action to observe the rod displacement (should be linear without blocking point).
3 month ago, I had a similar problem on my car and I had changed my 3/4" for a 7/8". The result was a pedal action harder only! Finally, I have decided to remove the trans to change my TOB (it is a kind of slave cylinder inside the bell housing that was not working properly). Now I have installed a 5/8" master cylinder and I have a smooth action with a good clutch progression (not ON -OFF style like the first test with the 7/8"). Hope these informations can help you
nanard289 is offline
Old 11-05-06, 06:28 AM   #7 (permalink)
albanygt40's Avatar
albanygt40
3 Tenths
Bernard when my clutch started to work I wasn't sure if should use
the 3/4 master cylinder with the shorter throw pedal and medium stiffness pedal feel or the soft long pedal with a 5/8 master cylinder. Ended up with
5/8 but I suspect I'll go back to the 3/4.
I'm just glad that all is working well now.
LinkBacks (?)
LinkBack to this Thread: http://www.gt40s.com/forum/gt40-tech-powertrain-transaxles/19717-016-kep-adapter-kit.html
Posted By For Type Date
GT40s.com This thread Refback 11-04-06 07:08 PM
Similar Threads
WTB adapter kit for Porsche g50 to ford 302 johnnyboy GT40 Wanted - Parts or Services Needed 0 11-01-06 09:21 PM
WTB adapter kit for Porsche g50 to ford 302 johnnyboy GT40 Wanted - Parts or Services Needed 0 11-01-06 09:18 PM
New 016 thread... CliffBeer GT40 Tech - Powertrain/Transaxles 20 10-17-06 01:09 PM
Kennedy Adapter for 302 to audi 016 pasadena-rob The Ebay Marketplace 0 07-21-06 08:59 PM
Pin-drive adapter nuts and sockets Mark Worthington GT40 Tech - Chassis,Brakes,Tires,&Wheels 44 06-03-04 02:40 AM
