Old 08-03-07, 12:08 AM   #21 (permalink)
minerl's Avatar
minerl
GT40: SPF P2133
Rep Power: 5 minerl has a spectacular aura about
Re: RBT stuck in reverse!
Bob
Thanks for the photo. This allowed me to make a plate that (I THINK) is very close to the aspect ratio, font and kerning in the photo. I made this one with white letters on black but nearly any color combo can be made. Does anyone know where these were mounted?
ID:	22463   Click image for larger version
Lynn
minerl is offline
Old 08-03-07, 03:53 AM   #22 (permalink)
JIMMYMAC
Rep Power: 17 JIMMYMAC has much to be proud ofJIMMYMAC has much to be proud of
Lynn,
Here is the position.
Cordially,
James
Graviner Fire Suppression
JIMMYMAC is offline
Old 08-03-07, 11:40 AM   #23 (permalink)
minerl's Avatar
minerl
GT40: SPF P2133
Thank you James
Lynn
minerl is offline
Old 08-05-07, 09:48 AM   #24 (permalink)
steve c
Steve
GT40: SPF GT40 P2125
Rep Power: 7 steve c has a spectacular aura about
Jeff,
Let us know what you found...Tx Steve
steve c is offline
Old 09-27-08, 11:40 AM   #25 (permalink)
2124's Avatar
2124
6 Tenths
GT40: Rescue, CA
Rep Power: 11 2124 is a glorious beacon of light
This is pretty scary and does not build confidence!
Yesterday I backed my car out of the garage so I could wash the garage floor. Nothing unusual happened, it shifted into reverse as it always does ( I have one of Ian Clarks shift kits in it that makes shifting a pleasure).
When I got done cleaning the floor I got in the car and put it into first - when I let the clutch out it exhibited the same problem that Jeff encountered. There was NO indication this was about to happen.
I am really, really glad it happened in my driveway and not while travelling. With a date.
Thanks to Jac Mac for pointing me in the direction of this thread.
CAV #80, 331 Keith Craft, RBT Swift DB5
2124 is offline
Old 09-29-08, 09:12 AM   #26 (permalink)
ross nicol's Avatar
ross nicol
Rep Power: 21 ross nicol has a brilliant futureross nicol has a brilliant futureross nicol has a brilliant future
You have a PM Pat
Ross
RF #025 currently racing
ZF,Motec injection
Lotus Europa S2
De Tomaso Pantera
ross nicol is online now
Old 09-29-08, 10:15 AM   #27 (permalink)
chuck 1's Avatar
chuck 1
8 Tenths
GT40: CAV
Rep Power: 12 chuck 1 will become famous soon enough
mine also does this, I can get it out of reverse with a little shifting around, however Olthoff says it is a detent spring or something like that. It is now being repaired at ZBT
chuck smith
CAV MONO GT40-302
SPF Daytona Coupe- Roush 427r
Kirkham 427 cobra- 427so
chuck 1 is offline
Old 09-29-08, 11:31 AM   #28 (permalink)
2124's Avatar
2124
6 Tenths
GT40: Rescue, CA
Thanks Ross -
Chuck - I'll call you later. Thanks.
2124 is offline
Old 11-25-08, 04:58 PM   #29 (permalink)
lbutfoy
GT40: Orange County,
Rep Power: 7 lbutfoy is on a distinguished road
Please fax any questions about the RBT box you may have to RBT (714)630-2453 i Will try to answer all your faxes ASAP or call M-F 9:00 to 11:30 am for tech (714)630-2450
lbutfoy is offline
Old 11-25-08, 06:27 PM   #30 (permalink)
Mudgey
Rep Power: 4 Mudgey is on a distinguished road
Hey. ive experienced this problem before with a customers car, this happened once and it was a pain in the ass as we couldnt get the backplate off without removing the rear tail cage. So what we did was drill and tap a hole for a bolt concentrically to the rod so we could simply remove the bolt and push the rod back into position if it ever happened again. Maybe this is something you guys could try it if its a reacurring problem! You could also fit a hard spring, as i think has already been suggested, to help push it back into place once you have moved it out of reverse.
Mudgey is offline
Old 11-25-08, 07:16 PM   #31 (permalink)
minerl's Avatar
minerl
GT40: SPF P2133
Jimbean
Have you got a photo of where you are suggesting a hole?
Lynn
minerl is offline
Old 11-25-08, 07:50 PM   #32 (permalink)
Mudgey
This is the best picture i can find, but you can see the black casing at the end of the gbox, this bolt was drilled n tapped in the same direction as the arrow, concentrically over the idler shaft, once the bolt was removed you simply inserted a punch or a small rod in the hole and pushed the idler shaft back into place and then reinserted the bolt.
This is a good quick fix.
Mudgey is offline
Old 11-26-08, 10:45 AM   #33 (permalink)
2124's Avatar
2124
6 Tenths
GT40: Rescue, CA
I apologize for not posting this earlier but a GT40s member, Oliver Ring (from Texas) sent me a PM simply stating that he had read my post and that if I wanted to call him, he could help me.
Mommy didn't raise a dummy - I called him immediately.
He gave me the solution and it was breathtakingly simple.
1. Drain the trans oil
2. Look into the drain hole, you will see a rod welded to a flat plate
3. Push the flat plate to the rear of the car - it will move about 6-8 mm
4. Replace drain plug.
5. Fill with oil.
6. Drive car.
Thanks Oliver!
2124 is offline
Old 11-26-08, 04:34 PM   #34 (permalink)
Mike Drew's Avatar
Mike Drew
3 Tenths
GT40: None, yet!
Rep Power: 7 Mike Drew is just really nice
That Oliver is undoubtedly Lloyd Butfoy's business partner, and the one physically constructing the new RBT gearboxes.
Great to see Lloyd and Oliver are now on this forum to help customers out!
Mike Drew, Vacaville, CA (MikeLDrew@aol.com)
'72 De Tomaso Pantera, '66 Contemporary 427 Cobra, '66 Shelby GT-350 clone, and gearing up for a Superformance Mk 1....
Mike Drew is offline
