Old 08-09-07, 10:56 PM   #1 (permalink)
chuck 1's Avatar
chuck 1
7 Tenths
GT40: CAV
difference in dash1 and dash2 ZF
what are the differences, and is a Dash1 ok for a 40? thanks; chuck
chuck smith
CAV MONO GT40-302
SPF Daytona Coupe- Roush 427r
Kirkham 427 cobra- 427so
chuck 1 is offline
Old 08-10-07, 04:38 AM   #2 (permalink)
Doc Watson's Avatar
Doc Watson
5 Tenths
GT40: Replica Mk I
Re: difference in dash1 and dash2 ZF
I think a ZF-1 has 4 hole mounting for the gearbox to the bellhousing and a ZF-2 has 6. The photos show this.
Also the -2 was 'beefed up' to take a little more punishment. I dont know if any external measurments are different. Also the ZF-1 is rare and spares will be harder to come by.
Anybody else?
Andy
ID:	22672  Click image for larger version
replica mono chassis
original rear clip
1966 289
48IDA's
This month its going to be red
'This car you have to be measured for...'
Doc Watson is offline
Old 08-10-07, 08:52 AM   #3 (permalink)
Chris Melia's Avatar
GT40: England Suffolk
Rep Power: 24 Chris Melia is a glorious beacon of light
Hi guys
Sorry to contradict but the -1 has larger input and output shafts
regards
Chris.
Chris Melia is offline
Old 08-10-07, 09:07 AM   #4 (permalink)
561234's Avatar
561234
GT40: SPF MKI #2214
Rep Power: 9 561234 will become famous soon enough
Cool Re: difference in dash1 and dash2 ZF
I believe the dash 1 has very close ratios with a lower 5th gear, the case has some external stiffeners between the bellhousing and trans(on a Pantera). the input shaft is too long. A Mangusta used a dash 1 that was oriented the same as a 40 but used a deeper bellhousing.
SPF MKI #2214, 65 R model clone, 67 Al Craft Indy Car, 03 SL 500, 02 Lightning
561234 is offline
Old 08-10-07, 01:17 PM   #5 (permalink)
chuck 1's Avatar
chuck 1
7 Tenths
GT40: CAV
thanks guys. Next question, what mods need to be made to a BMW M1 ZF to mate to our 40's? chuck
chuck smith
CAV MONO GT40-302
chuck 1 is offline
Old 08-10-07, 03:09 PM   #6 (permalink)
Russ Noble's Avatar
Russ Noble
New Zealand
GT40: Building scratc
Chuck,
Is this post by Ross Nicol the sort of info you are looking for?
18 months with a ZF Transaxle
Cheers,
Russ Noble is offline
