Old 09-05-07, 11:47 PM   #1 (permalink)
CMV
Brazil
Rep Power: 2 CMV is on a distinguished road
Semi automatic transaxles
Hello,
I have access to Porsche trans axles including the latest semi automatic. But before I start shipping I would like to know if anyone as tried this on their GT40. As anyone tried any brand of semi automatic trans axle?
351 SBF stroked/427.
Thanks for feedback
Miguel
CMV is offline
Old 09-06-07, 09:20 AM   #2 (permalink)
Dalton
4 Tenths
Rep Power: 8 Dalton is just really nice
Re: Semi automatic transaxles
Forty drivers like to be crammed into small spaces with no openable windows, and noise and heat and manual steering and having to drive the gearbox and heaps of unadulterated power. If convenience was wanted they would be driving A-Class Mercs and banking the loose change. So while a Tiptronic would be damn fast, it would probably not be wanted or good for resale value.
Dalton
Dalton is offline
Old 09-06-07, 02:35 PM   #3 (permalink)
CMV
Brazil
Thanks Dalton as a matter of fact it will be for racing. I realize what the essence of the GT40 is all about, but we already take advantage of modern materials for racing and even for street use.
For me and some of my racing buddies the clutch is irrelevant to speed and excitement.
Thanks again
CMV is offline
Old 09-06-07, 04:41 PM   #4 (permalink)
toy264's Avatar
toy264
Rep Power: 6 toy264 will become famous soon enough
It would also be of interest to those with limited mobility.
toy264 is offline
Old 09-08-07, 07:57 PM   #5 (permalink)
FOX1's Avatar
FOX1
4 Tenths
Italy
GT40: none
Rep Power: 6 FOX1 is a glorious beacon of light
Friends,
it is not that easy to fit a semi automatic synchronised gearbox in a car. It is a OEM matter.
You will find attached the description of an automation system, semi automatic with up shifting and down shifting on demand, secured against wrong requestes. On top of it there is the automated drive away and the automatic down shifting during slow down manouvres.
For us this is called level 4. The level 3 does not have the automatic drive away which is handled through a third paddle on the steering wheel, but the automated clutch operation during shifting is there. In the level 4 there is another security gadget which is the clutch protection.
- If somebody is holding the car up hill without hill holder assistance, as soon as the sensor detects the 1st level of danger it will show on the dashboard....PUSH BRAKES...PUSH BRAKES....if this does not happen, then the system will pull the electric hand brake, open the clutch for down cooling and start on the hazard signal supported by intermadiate horns.
Pls find attached the level 4 which has an application cost of about 350.000 € if the engine is already drive by wire with a can bus for comunication with the gearbox GCU and the car is already equipped with an electric hand brake or an hill holder assist.
Have a look how it works, pls.
Wanni
AUTOMATION - COMPONENTS - DESCRIPTION.
1) ELECTRO-MECHANIC GEAR ACTUATOR.
The electric actuator for the control of the sequential gearbox comprises an electric motor and a mechanism for transforming rotary motion into linear motion of the element connected to the command lever of the gearbox.
Inside there is a thrust crank that performs a complete rotation returning to its start position, there is a crank stud positioned rotating with the action of the said electric motor. The stud engages a cam, made in the form of a template, fashioned in a plate sliding in a guide. The actuator can rotate clockwise or anticlockwise depending whether the gear change is up or down. A complete rotation, 360 degrees of the crank, realises a corresponding complete translation of the gearbox lever for one gear change producing the necessary stroke of the lever to pass from the middle position to the extreme position and to come back again. Definitively the actuator reproduces the same operation made by the hand of the driver that pushes (or pulls) the gear command lever in the cockpit. The electric actuator is connected to the gearbox drum command with a preloaded elastic joint. This element rigidly actuates a gear change operation until the reaction load of the syncro are equal to the joint preload. In this way it is possible to prevent possible dangerous overloads on the syncro, cutting off also additional inertia loads of the actuator. At the same time the actuator can continue its travel submitted to this elastic load, until the syncro completes its job and a complete gear change is possible.
The actuator is instrumented with a position sensor; in addition to the one on the barrel it is possible to recognize what is happening during gear change.
More gearshift operations are possible in a very short time with this electrical actuator that always rotates in the same direction until the last requested ratio is reached.
In this situation normally the clutch is realised only at the last gear.
Integrated on the electric actuator there is an electric motor speed sensor that allows a complete PID control strategy and a switch that identify the middle position of the template for recovery and safety strategies
2) CLUTCH ROBOTISED DEVICE.
The electric actuator for the clutch control comprises an electric motor and a mechanism for transforming rotary motion into linear motion of the hydraulic pump connected to the slave cylinder concentric to the clutch.
Inside there is a thrust crank that performs a complete rotation returning to its start position, there is a crank stud positioned rotating with the action of the said electric motor. The stud engages a cam, made in the form of a template, fashioned in a plate sliding in a guide. The actuator can rotate clockwise or anticlockwise depending from the necessity to control the clutch position. A complete rotation, 360 degrees of the crank, realises a corresponding complete cycle of opening and closing of the clutch. Definitively the actuator reproduces the same operation made by the foot of the driver that pushes and modulates the clutch pedal inside the cockpit. The electric actuator is connected to the clutch slave cylinder with a pipe.
The cylinder is auto regulating during clutch life as the traditional hydraulic pedal pump.
Similarly to the gearbox electro actuator, the clutch actuator is instrumented with a position sensor in addition to the one installed on the cylindrical slave cylinder. This solution permits to recognise what is happening during clutch life, and allows many safety and recovery strategies.
More opening clutch operations are possible in a very short time with this electrical actuator that can rotate in the same direction until the last requested ratio is reached.
In this situation the clutch actuator never reverses its motion, obtaining a fast action with a very low electrical consumption.
Integrated on the electric actuator there is an electric motor speed sensor that allows a complete PID control strategy and a switch that identify the middle position of the template for recovery and safety strategies.
TRANSMISSION AUTOMATION
1.) Functions, basic gear shift strategy,
Hardware, Software and Software development steps
Driver’s interface:
• Gear shifting: Pads on the steering wheel (up – down)
• Shift mode selection: “Manettino” on steering wheel or centre console
• Transmission pre-selection (P, N, D, R, etc.): switches on the centre console
• Selected transmission mode display: Display of selected mode and gear on dashboard
• Output for display:
clutch wear display
clutch overheating display
automation failure display
Gear up shift phases:
• Input to up shift a gear (throttle can be in any position)
• Feasibility check and strategy selection
• Dialogue with engine E.C.U. for revs and torque control
• Clutch opening (in according to selected strategy)
• Gear up shift (in according to selected strategy)
• Clutch closing (in according to selected strategy)
• Torque increasing up to target and selected strategy
• Return to management of engine E.C.U.
Gear down shift phases:
• Input to down shift a gear
• Gear down shift (in according to selected strategy)
• Rear wheel spin control by clutch slide control
Drive away:
• Brake switch on
• Selected first gear
• Brake release
• Clutch release modulation according to driver torque requested
• Brake on and throttle fully released: clutch fully opened
Gearshift strategy:
• By reaching maximum revs transmission does not up shift automatically.
• Down shift input in wrong rev conditions to ignore.
• Kicker during sport down shifting.
• Advanced down shift clutch management
• Automated down shifting during slow down manoeuvres and significant gap between actual gear and speed (by vehicle stopping, first gear remains engaged)
Shift Modes:
• Normal. Comfort oriented torque reduction / torque increasing and clutch opening / clutch closing.
• Sport. Time oriented torque reduction / torque increasing and clutch opening / clutch closing.
• Wet. Stability oriented torque reduction / torque increasing and clutch opening / clutch closing.
N.B.: No fully automated gearshift mode.
2.) Software: Basic Functions
• CAN bus management
• Driver management
• Strategy
• Mapping management
• Gear shifting for 3 driving modes plus 1 automated down shift mode
• Drive away
• Clutch overheating prevention management
• Fail safe strategies
• Auto check
• Diagnostics
3.) Hardware: Basic component description
• 32 bit ECU Microcontroller FreeScale Mac 7100 series (Motorola) automotive
• CAN bus
MINIMUM OUTPUT:
• Driver for n°2 full bridge D.C. Motor control (100 A peak value, 20 A continuous)
• PWM for proportional solenoid differential valve (3 A max.)
• Solenoid reverse lock (3 A max.)
• Solenoid key drum (3 A max.)
• Solenoid additional (3 A max.)
MINIMUM INPUT:
• n°2 counter for electric D.C. Motor
• n°4 counter for pick up speed sensors
• n°6 analogue input +n°2 additional analogue input
• n°16 digital input
SENSORS and SWITCHES description:
• n°2 analogue position sensors on actuators
• clutch position sensor
• air clutch temperature sensor
• drum position sensor
• oil temperature sensor
• brake switch
• n°2 paddle switches (N.C. and N.O.)
• pick up primary shaft
• pick up final shaft
• n°2 pick up for active differential (sx axle shaft, dx axle shaft)
• n°2 microswitch on actuator
• n°3 switches for modality selection
• n°4 switches for drive mode
N.B. The Hardware dimensions allow future upgrading and developments in Software tools, e.g. Active differential.
4.) Software development steps
• Step 1: Gear shifting Normal, Sport and Wet mode, throttle off management, automated down shift management, clutch overheating prevention management, development diagnostics.
• Step 2: Step 1 plus fail safe strategies, auto check, diagnostics.
• Pre-production: Step 2 plus (definition of maximum number of failures permitted per km)
• Flashing
Not that simple.
FOX1 is offline
Old 09-08-07, 08:15 PM   #6 (permalink)
FOX1's Avatar
FOX1
4 Tenths
Italy
GT40: none
Originally Posted by FOX1 View Post
Friends,
Wanni
Driver’s interface:
clutch wear display
Drive away:
• Brake switch on
• Brake release
Gearshift strategy:
Shift Modes:
• Driver management
• Strategy
• Drive away
• Auto check
• Diagnostics
• CAN bus
MINIMUM OUTPUT:
MINIMUM INPUT:
• brake switch
• Flashing
Not that simple.
I will try to add a scheme, but it is not easy due to the size limitations.
Name:	Foxmatic electric AMT.jpg
FOX1 is offline
Old 09-08-07, 09:40 PM   #7 (permalink)
Miguel V
Brazil
Rep Power: 2 Miguel V is on a distinguished road
Wanni,
How much for all this ? Where can I get all the parts.
Miguel V is offline
Old 09-08-07, 11:55 PM   #8 (permalink)
FOX1's Avatar
FOX1
4 Tenths
Italy
GT40: none
What's your program?
This is the system developped by Gearfox and Automac. The trade mark out of this joint venture is Foxmatic.
Do not ask me for a single application, it is too expensive.
At least you shall split it on 30 vehicles.
Wanni
FOX1 is offline
Old 09-09-07, 01:20 PM   #9 (permalink)
Howard Jones's Avatar
If I was in need of a automatic in a GT40 and beginning the build I would see how a Porsche Boxer fit before I went any further. It will not need to be "flipped" and is in the correct orientation from the outset. If you can get in into the car then the electronics will need to be worked out. You might begin with the electronic question even before you do any physical mock-up in a car. You will need to solve these issues anyway and doing so in advance would be relatively inexpensive compared to the rest of the project. At least in a on paper conceptual way.
One other type to research would be a early Audi automatic 2wd version. There might be somewhat less electronics in a early Audi.
Overall length and depth (below the center-line of the output shafts will be the critical points. There's really not much room in these cars so I don't think any automatic transaxle is going to "drop in" without at least some cutting and welding.
Anything can be done with either a lot of hard work on the builders part or a lot on money or a lot of both. There has been some discussion here on this subject form time to time but I don't recall a completed car with a automatic in it.
Howard Jones is offline
Old 09-09-07, 03:08 PM   #10 (permalink)
IanAnderson's Avatar
IanAnderson
Gold Supporter
GT40: Dax 40 Mk1 (Rov
Rep Power: 19 IanAnderson is a jewel in the rough
There was also an automatic version of the UN1
Not much good for racing but fot the less mobile it has potential
IanAnderson is offline
Old 09-09-07, 07:37 PM   #11 (permalink)
Ian is correct. They were used in Delorian's and are extensively supported on several Delorean websites that supply all manner of Delorean parts. If you live in the USA there are several and they have turned out to be a good parts source for the 5 speed R21 version also.
Old 09-10-07, 08:32 AM   #12 (permalink)
Eric Martin
GT40: none now, planning one
Rep Power: 6 Eric Martin is on a distinguished road
This is an issue that I am also interested in. I am building a mid-engine car (not a GT40) and I have a customer who wants an automatic. I am looking at the Boxster S triptronic but I am not sure what the electronics will be like. Can anyone give me some information about what all will be involved with hooking one of these up? Are there any particular years of manufacturer that might be easier to work with? This car will have an LS1 V8 which has electronics and it might be possible to incorporate the transaxle electronics into the engine system. Thank you.
Eric Martin is offline
Old 09-10-07, 06:23 PM   #13 (permalink)
FOX1's Avatar
FOX1
4 Tenths
Italy
GT40: none
I think we are far away one from the other,
For my point of view you are making it too semplicistic.
I am not selling troubles. Anyway you are free to join other applications.
Wanni
FOX1 is offline
Old 09-10-07, 08:59 PM   #14 (permalink)
mikey t
Rep Power: 2 mikey t is on a distinguished road
