Hi
my build is a Minotaur www.minotaurkitcar.co.uk anyways I bought a G64 gearbox the question i have is does anyone see a prob converting this to 2wd serial no G64003L07394 i believe its a porsche 964 year 1990 ,awd i have stripped the top end of the box down so i could check the main gears as i found a broken tooth , everything is good and the tooth came from the front wheel drive part of the box.
the confusion i have is that the shaft that turns the diff is inside the main gearbox shaft if that makes sence so when i turn the diff crown gear it doesnt turn the box. im very confused and am going to have to reassemble the whole box before i spend £100 on gaskets. any thoughts or help would be great
thanks guys...--
does anyone know how the power from the engine gets to the rear wheels if these 2 shafts are free to rotate?
any help or thoughts would be great im assuming if i can make a 2 splined top hat to tie the 2 shafts together it will solve the problem?
thanks stu [email protected]
thanks guys...--
