Old 11-14-07, 06:37 PM   #1 (permalink)
Bobs 9401
GT40: non yet
Rep Power: 2 Bobs 9401 is on a distinguished road
UN 1 linkage
Hi,
I resently purchased a UN 1 trans, but have no linkage set up for it, my car has a double cable set up would anyone have a good picture of there set up that I could follow(copy) for my car. Ill post pictures of the trans if it would help.
Thanks,
Bob
Bobs 9401 is offline
Old 11-15-07, 05:20 AM   #2 (permalink)
Julian West's Avatar
Julian West
7 Tenths
GT40: GTD
Rep Power: 14 Julian West has a spectacular aura about
Re: UN 1 linkage
Bob,
Here are a few pictures of a standard setup as supplied by GTD. Hope they help.
Regds,
Julian West is offline
Old 11-15-07, 05:30 AM   #3 (permalink)
wealdenengineer
Rep Power: 17 wealdenengineer has a spectacular aura about
Re: UN 1 linkage
Bob, If you are missing any parts I have most of them in my used parts bin, free of charge except carriage, Frank
wealdenengineer is online now
Old 11-15-07, 08:47 AM   #4 (permalink)
Bobs 9401
GT40: non yet
Re: UN 1 linkage
Julian,
Thanks a ton for the pictures they are great and answer a lot of my questions. and Frank I'll PM you on the missing parts I need for mine and thanks a million to both of you.
Bob
Old 11-15-07, 04:32 PM   #5 (permalink)
Bobs 9401
GT40: non yet
Re: UN 1 linkage
Hi,
After looking over my trans I noticed it doesn't look the same as Julians trans. would anyone be able to ID my trans by these pictures?
Thanks,
Bob
Old 11-15-07, 06:05 PM   #6 (permalink)
Scott Calabro's Avatar
Scott Calabro
Supporting Vendor
GT40: TS40 # 875
Rep Power: 10 Scott Calabro is a splendid one to behold
Re: UN 1 linkage
Hi Bob,
What does the tag that is on the rear cover, at the 5 o'clock position, have stamped on it?
From what I can see of casting marks on the rear cover, it was cast in either '85 or '83. Its difficult to read.
If it is in fact one of the more desirable axles, you have an ideal setup for a rod type shift linkage set-up, as you seem to have the single cross shaft, shift mechanisim.
Cheers,
Scott
TORNADO SPORTS CARS USA
WWW.TORNADOSPORTSCARS.COM
413-977-4408
Scott Calabro is offline
Old 11-15-07, 06:44 PM   #7 (permalink)
Malcolm's Avatar
Malcolm
Gold Supporter
GT40: GTD
Re: UN 1 linkage
Consider changing those knuckle joints to heim joints for a more precise change. Also heat sheild the cables and joints aroud the gearbox end as they will get hot from the exhausts.
Malcolm
GTD40, Mazda MAX5 MX5, Porsche 996 C4S
Prosport 3000 Spyder for sale, Lotus 51c for sale
Malcolm is online now
Old 11-15-07, 10:17 PM   #8 (permalink)
Bobs 9401
GT40: non yet
Re: UN 1 linkage
Good advice Malcolm I'll remember that when it comes time to final fit the trans
Old 11-16-07, 03:48 AM   #9 (permalink)
wealdenengineer
Re: UN 1 linkage
The box looks like a version of the earlier GTD box based on the Reault 30, having a final drive ratio of 3.88, not 3.44 of the R21T box that is most favoured. If so you will be limited in top end speed ---- Frank
Old 11-19-07, 01:34 AM   #10 (permalink)
RamboLambo
New Zealand
GT40: Whangarei New Z
Rep Power: 8 RamboLambo is on a distinguished road
Re: UN 1 linkage
Looks like an R30 box. If so, it has the 3.89 final drive, but the added advantage of a 4-spider diff unit. The type of box it is, is engraved on the back of the crownwheel. You will probably see the markings 369 .... whatever .... This indicates a Renault 30 or 20 box. Count the number of spider gears in the diff, if there are 2, its probably a Renault 20, that has a 4.11 diff. I'll check my stash of Renault Bellhousings - the position of the starter was different on the V6's to the 4's.
Bruce
RamboLambo is offline
Old 12-13-07, 05:40 AM   #11 (permalink)
hydra's Avatar
hydra
Russian Federation
Rep Power: 5 hydra is on a distinguished road
Re: UN 1 linkage
I don't mean to hi-jack this thread, but does anybody have pics/information on a rod-type linkage for the UN1? I did a search and couldn't find anything, thanks!
hydra is offline
Old 12-13-07, 07:34 AM   #12 (permalink)
MikeP's Avatar
MikeP
2 Tenths
GT40: GTD + GTD
Rep Power: 5 MikeP is on a distinguished road
Re: UN 1 linkage
Here is a pic of a rod change set up on a GTD.
MikeP is offline
Old 12-13-07, 09:21 AM   #13 (permalink)
saxoncross's Avatar
saxoncross
GT40: Tornado
Rep Power: 2 saxoncross is on a distinguished road
Re: UN 1 linkage
As I'm in the middle of collecting parts for a UN1 rod-shift mechanism for my Tornado, I've finally got my head around what I need. Tornado sell a complete system, as shown, but I plan to use the previously mentioned GTD design, with the gear-lever end similar to what Ultima use.
Hope this all helps
Andy
saxoncross is offline
Old 12-13-07, 09:55 AM   #14 (permalink)
Scott Calabro
Supporting Vendor
GT40: TS40 # 875
Re: UN 1 linkage
Hydra,
Part number 40-67 Right hand rod type gear linkage, complete including selector lever and all fixings.
395.00 Pounds Sterling
Any questions at all just call or e-mail.
Merry Christmas,
Scott
413-977-4408
Old 12-13-07, 08:33 PM   #15 (permalink)
hydra's Avatar
hydra
Russian Federation
Re: UN 1 linkage
Thanks for all the pics and info guys - keep it coming!
Scott, this isn't going in a GT40, I'm building a 914 with a Mustang 5.0 and UN1...
hydra is offline
