Old 12-18-07, 07:24 PM   #1 (permalink)
Joz
Joz's Avatar
Joz
GT40: Magnum 246 GT
Rep Power: 2 Joz is on a distinguished road
All wheel 016
To All,
I just looked thru the files and could not find much on using a all wheel 016 transaxle in a mid engine set up. What is the groups opinion???
Joz
Joz is offline
Old 12-18-07, 09:51 PM   #2 (permalink)
Howard Jones's Avatar
Rep Power: 25 Howard Jones is a jewel in the rough
Re: All wheel 016
The conversion isn't worth the effort. The FWD Audi's are fairly easy to come by and inexpensive. The cost to convert a 4WD version would be many times the cost of a 2WD equivalent. Better to spend the money on a rebuild of a 2WD or if I had a 4WD version I would attempt to trade it for a 2WD version and then rebuild it.
Howard Jones is offline
Old 12-19-07, 02:37 AM   #3 (permalink)
Lambo's Avatar
Lambo
Rep Power: 3 Lambo is on a distinguished road
Re: All wheel 016
Hi Howard and Joz, Maybe i have missed something, i have two of the 016 4wd boxes in my garage and the awd box is exactly 180mm longer than the 2wd, i have not been able to figure out how the rear section comes off, does anyone know.It is not like the 2wd with a large nut behind the rubber bung.
It would appear from looking at an exploded view that it is possiable to lock the centre diff with the mechanizm at the rear and so send all the drive up the hollow shaft to the pinion shaft.The rear flange will still turn in sync with the driving shafts.
Lambo
Lambo is offline
Old 05-23-08, 07:59 PM   #4 (permalink)
wment
GT40: Valkyrie
Rep Power: 3 wment is on a distinguished road
Re: All wheel 016
I acquired a 4wd 016 trans real cheap and since the dimensions are the same as the 2wd 016 until you get back to the rear output part I used it when mocking up my eng and trans mounts. I got a 2wd unit later and just swapped out the 4wd unit.
Wayne
wment is offline
Old 05-24-08, 11:04 AM   #5 (permalink)
Joz
Joz's Avatar
Joz
GT40: Magnum 246 GT
Re: All wheel 016
Lambo,
I have not done any research on the Audi AWL box, what I know about that one and the FWD boxes is what I have read here. I plan on using a FWD box, if I can find the right one and if any are out there maybe a 6 speed FWD box. Several members have stated that the 6 speed is somewhat stronger then the 5 speed. My search for a A4 6 speed so far has been "0" results.
Does anyone know if the Porsche 944 Turbo LSD will fit in the Audi 6 speed?
Joz
Joz is offline
Old 05-25-08, 02:48 PM   #6 (permalink)
GT40: Atlanta
Rep Power: 6 RUFAZZ is on a distinguished road
Re: All wheel 016
Joz,
The 944 box wont work, it doesnt have clutch provisions.
RUFAZZ is offline
Old 05-25-08, 06:52 PM   #7 (permalink)
wolodymyr's Avatar
wolodymyr
GT40: DAX40
Rep Power: 9 wolodymyr is on a distinguished road
Re: All wheel 016
Lambo, this sounds correct, but you would need to check that the components are the same strength/size as in the FWD box. The reason I say that is that a FWD box transmits all the torque to 1 axle, so in theory has to be stronger than an AWD which shares the torque between two. I don't know whether that is so in this case, can anyone enlighten us on this?
Dave
DAX 302 Installing Alloy Rad
wolodymyr is offline
