Old 01-25-08, 11:55 AM   #1 (permalink)
Bigblockquad
GT40: SPF GT
Rep Power: 2 Bigblockquad is just really nice
ZF Shifting
I'm currently running an RBT transaxle and am satisfied but not impressed with it. Until more testing is done on the ZQF,it will remain installed but not for long. I know it will eventually come out in place of the new Quaife or Mendeola box.
P.S. Does anybody know where I can get a set of the rear view mirrors installed on that 40 and what they are called.
Rich.
Bigblockquad is online now
Old 01-25-08, 12:47 PM   #2 (permalink)
Gary Kadrmas's Avatar
Gary Kadrmas
Silver Supporter
GT40: Not yet, but so
Rep Power: 12 Gary Kadrmas has much to be proud ofGary Kadrmas has much to be proud of
Re: testing the ZFQ gear box
mirrorviewrear.com
Gary Kadrmas
___________________
Owner of CSX-2075 for over 30 years, and wanting a GT40 for over 20 years
Gary Kadrmas is offline
Old 01-25-08, 01:02 PM   #3 (permalink)
wealdenengineer
Rep Power: 17 wealdenengineer has a spectacular aura about
Rich, we supplied and installed the mirrors on the Mk2, Frank
wealdenengineer is offline
Old 01-25-08, 01:18 PM   #4 (permalink)
steve c
Steve
GT40: SPF GT40 P2125
Rep Power: 7 steve c has a spectacular aura about
Rich E
What is your complaint ("satisfied but, not impressed") re the ZF?
Steve P2125
steve c is offline
Old 01-26-08, 02:24 PM   #5 (permalink)
Bigblockquad
GT40: SPF GT
Steve C,
A couple of things I've noticed:
1) The gear changes don't feel as positive as I'd like.
2) Finding 1st and reverse could be easier.
3) The movement from 3rd to 4th doesn't feel as natural as it should.
4) I wish it would hold more fluid.
I guess I've just just gotten used to modern transmissions.
My .02
Rich.
Old 01-26-08, 03:04 PM   #6 (permalink)
steve c
Steve
Rich,
I have SPF P2125 LH drive Center rod shift (custom install by Olthoff) with same shift mechanism as SPF uses on RH rod factory installs but adds 2 across the car connecting rods to marry to the RH sill rod (some pics in my posts in Superformance Forum). Install uses the gearshift and plate as original cars.
I have been told to always shift to 2'nd with clutch in before any 1'st or reverse shifting as it best alignes the gearing selectors. I use this preceedure with my Tremec transmissioned car and never had lock up problems others have or difficulty in 1's or reverse engagement and it seems to work for the ZF as well.
Well to your comments: I did find it difficult to "find 1'st at first but, as I drove the car more I seemed to know where to go....reverse OK as well as 3'rd to 4'th and engagement in gears not much different than the Tremec...As to fluid capacity; do you have any reason to think it's not sufficient?
Don't know when your car was built or by who but, 2 possible options to consider: 1) If you have an early car I know that Olthoff has developed an "impproved" cable shift set-up (your issues might relate to older cable shifter?)...2) I think you can retro easily to rod shift if your car is RH drive as I understand all the cars have the necessary firewall cut-out for the rod to engine bay.
Steve P2125 LH with rod shift to ZF
steve c is offline
Old 01-26-08, 05:33 PM   #7 (permalink)
Chris Melia's Avatar
GT40: England Suffolk
Rep Power: 23 Chris Melia is a glorious beacon of light
Hi guys
I can attest to the improved cable shift that Dennis Olthoff has developed. It worked very positively with the ZFQ.
regards
Chris.
Chris Melia is offline
Old 01-26-08, 05:47 PM   #8 (permalink)
Gary Kadrmas
Silver Supporter
Steve C,
Is your rod shift set-up similar to what was used on the Pantera? The '72 I had back in '79 reacted the same as far as going to 2nd, then first, with no engagement problems. I do remember the 1st to 2nd gear shifts needed to be timed just right and on the slow side in order for it to feel right as you slid it into 2nd gear.
Gary Kadrmas
___________________
Old 01-26-08, 07:53 PM   #9 (permalink)
steve c
Steve
Gary,
I don't know what was used in Panteras but, have attached below a few pics of LH center rod shift as developed and installed by Olthoff.
steve c is offline
Old 01-26-08, 08:16 PM   #10 (permalink)
steve c
Steve
Chris M,
Sorry...I seem to have hijacked your thread in response to Rich E's comments on the ZF and then you responded re Dennis' inproved cable shifter for the SPF and then Gary re ZF shifting and me again re Olthoff's LH rod shift....Guess tail of this thread should go into the Superformance Forum BUT, I don't know how to.
Will someone help move this so this thread can speak to the ZFQ as was intended?
Tx, Steve
steve c is offline
Old 01-27-08, 02:38 AM   #11 (permalink)
Gary Kadrmas
Silver Supporter
Sorry for the thread drift. Lets keep this as is, and I will fade out stage left.
PS: Thanks Steve for the pics.
Gary Kadrmas
___________________
Old 01-28-08, 02:58 AM   #12 (permalink)
ross nicol's Avatar
ross nicol
Originally Posted by Bigblockquad View Post
Steve C,
My .02
Rich.
I run an RBT in my race car and after upgrading the gearshift 3 to 4 times to cure the symptoms you have described in 1,2,3 above I have no doubt your problems are not gearbox related. As to #4, I wish my box would hold less due to the very expensive oil I use. Be a pretty expensive exercise too, to replace the box only to find it made no difference and your diagnosis had been in error.
Ross
RF #025 currently racing
ZF,Motec injection
Lotus Europa S2
De Tomaso Pantera
ross nicol is offline
Old 01-28-08, 03:56 AM   #13 (permalink)
Bigblockquad
GT40: SPF GT
Re: ZF Shifting
I'll talk to Olthoff about the shifting mechanism. It would be nice to solve alot of the issues I have about the tranny by switching over to rod shift.
P.S. Not so sure I'd loose money on the transaxle.......If I was to sell it I'm sure someone would love to not have to wait a year to get the car running. Just an idea though.
Rich.
Old 01-28-08, 05:40 AM   #14 (permalink)
Re: ZF Shifting
Hi Rich
try Olthoff's mod on your cable shifter, it is just a more positive set of levers mounted on the tranny, a simple bolt on.
Chris.
Old 01-28-08, 09:29 AM   #15 (permalink)
steve c
Steve
Re: ZF Shifting
Rich E,
I agree with Chris' post above and the improved Olthoff cable shift was what I was suggesting in my earlier post.
Although I like and wanted the center rod shift it is a significantly more complicated retrofit and I'm sure more costly (if cost is an issue) so I would talk to Deennis about the "improved"cable if you want an easy retro/upgrade.
I agree with your comment re Chris' ZFQ but, after communication with Chris (and at his suggestion) wheras my car is complete I will wait and see if and when I need the "Q" and install then (THANKS again Chris for your advice)
Steve
steve c is offline
Old 01-28-08, 12:00 PM   #16 (permalink)
Martin Weigold's Avatar
3 Tenths
GT40: Gibraltar
Rep Power: 10 Martin Weigold is on a distinguished road
Re: ZF Shifting
I don't have any issues at all with shifting in my ZF - it's as sweet as a nut, but I do use a rod shift mechanism with a copy of the original cars' gear shift mechanism, so maybe that's it.
GTD MKI, 302 cu in Ford V8 with Webers, 430 BHP, ZF Transaxle, 15" knock-ons, lowered engine using Southern GT chassis at rear
Martin Weigold is offline
Old 01-28-08, 12:45 PM   #17 (permalink)
Dogface's Avatar
Dogface
GT40: RF 115
Rep Power: 1 Dogface is on a distinguished road
Re: ZF Shifting
I talk to many zf owners. It seems to be a inherited symptom of trouble that it is a little hard to shift into reverse. I was told to try this before going into reverse 1. stop the car fully.2. shift into first gear.3. than shift into reverse. I tried this and it goes into reverse like butter ever time. I was told that the it was a design flaw that is inherit with all Zf's. As for all the forward shifts, I'm very satisfied with the shift smoothness in my ZF. However, I have a solid link to the Zf. I think cable may be a culprit with shifting problems.
just my 2 cents
john
just my 2
Dogface is offline
Old 01-28-08, 01:03 PM   #18 (permalink)
ssm
GT40: GTD.SGT001.
Rep Power: 5 ssm is on a distinguished road
Re: ZF Shifting
I also have a rod shift with original type gear shift which works fine on my zf set up and it also worked with no problems when testing the zfq.
Mick.
ssm is offline
Old 01-28-08, 06:23 PM   #19 (permalink)
Pantera1889's Avatar
Pantera1889
GT40: RCR MK1
Re: ZF Shifting
I have one of each ( cable in the GT40 and rod in the Pantera) I actually prefer the RCR cable mechanism in the GT40.
RCR GT40 MK1 chassis #14
DeTomaso Pantera #1889
Pantera1889 is offline
Old 01-28-08, 07:03 PM   #20 (permalink)
steve c
Steve
Re: ZF Shifting
So...Maybe all in the set-up NOT the ZF?
Steve
steve c is offline
