| Re: Oil Leak from ZF Tom
When you remove the cover you do have to take care.There are 2 bearings with shims that will either stay inside the cover or stick to the back of the bearing, if the latter is the case get the shims off the bearing and place them in their correct location in the cover immediately. Make sure they cannot fall out. There is also a spring loaded pin which is part of the reverse gear detent.I suggest a manual would be a good Idea and if you have no luck sourcing one in the UK, you can purchase through the Pantera club in the US or I would have one here.
Ross
__________________ RF #025 currently racing
ZF,Motec injection
Lotus Europa S2
De Tomaso Pantera |
