Old 06-25-08, 04:48 PM   #1 (permalink)
Nick Brough's Avatar
Nick Brough
GT40: ford 351W G50
Rep Power: 3 Nick Brough will become famous soon enough
G50 gear positions
Hi,
Is anyone able to advise me of the correct positions for the 5 gears and reverse for a porsche G50 gearbox. As per the attached picture there seems to be 4 positions for 6 gears i.e. 1st plane in, middle (is this neutral), and out, 2nd plane (middle of 1st plain then clockwise against spring) in, then out.
Hope this makes sense.
Kind Regards
Nick
Nick
Nick Brough is offline
Old 06-25-08, 05:05 PM   #2 (permalink)
jac mac's Avatar
jac mac
New Zealand
Rep Power: 20 jac mac has much to be proud ofjac mac has much to be proud of
Re: G50 gear positions
Nick, if your shift pattern is correct, from the middle plane(neutral) you should be able to find two positions rearward (2nd & 4th) and four forward ( rev-1st-3rd-5th ). Rev & 5th will require some extra twist force on the shaft in order to overcome the detent-rev more so than 5th. ( this is working directly on the shift rod as it exits trans at rear )
Jac Mac,
DIY Mono MkIV,390,J44,15" Turbines.
jac mac is offline
Old 06-26-08, 06:01 PM   #3 (permalink)
Nick Brough
GT40: ford 351W G50
I think the problem is I may be expecting to much of a deflection on the shaft when going from 1st and 2nd to 3rd and 4th. Can anyone advise on the amount the bar should deflect anticlockwise to select the 2nd plane (3rd and 4th).
Nick
Nick
Old 06-26-08, 06:25 PM   #4 (permalink)
jac mac's Avatar
jac mac
New Zealand
Smile Re: G50 gear positions
Just checked mine --10° from 1/2 to 3/4 gate, Total of 30° from reverse to 5th gates. This at trans.
Jac Mac,
jac mac is offline
Old 06-27-08, 06:22 AM   #5 (permalink)
Nick Brough
GT40: ford 351W G50
Thanks for the reply, I now definitely can select 1st 2nd and reverse (definite detent), I believe I have 3rd and 4th, hope so as if I don't there is a problem with the box, that just means I have 5th to still find.
Nick
Nick
Similar Threads
G50 gear positions Nick Brough GT40 Tech - Powertrain/Transaxles 6 06-01-08 07:18 PM
SPF GT Switch and Control Positions minerl HOW TO: Interior, Exterior, AC, & Trim 0 01-20-08 08:06 PM
Top Gear JIMMYMAC The Paddock 10 02-15-07 04:17 AM
Fifth Gear Paul B GT40 Enthusiasts Club 3 05-04-06 06:42 PM
Best Top Gear ever? Chris Edwards All GT40 26 12-25-04 05:06 PM
