Old 07-19-08, 12:08 PM   #1 (permalink)
mv1313
Sweden
Ford GT Ricardo transaxle
Hello! Iam from Sweden thats why it quite bad english.
I have a Ford GT transaxle, not much space left but I shall try to build anyway. Which flywheel and clutch? The starter coing to be in wrong place also, it should be much better if i can screw it from the motor block.
mv1313 is offline
Old 07-19-08, 06:14 PM   #2 (permalink)
jac mac's Avatar
jac mac
I Have No Life
New Zealand
Re: Ford GT Ricardo transaxle
You appear to have a complete Ford GT motor and transmission assy, or at least a trans and motor that match without any adaptor plate etc, so why change that? Would it not be simpler to use original GT Flywheel/Clutch and starter and modify the space frame slightly in the starter area for clearance.
Jac Mac
jac mac is offline
Old 07-21-08, 09:02 AM   #3 (permalink)
jferraro's Avatar
jferraro
GT40: RCR40
Hi Magnus, agree with Jac Mac. Use the original starter and clutch pack. Best way to go. I have a different chassis (RCR) and even that is VERY tight. Using the OE accessories will give you the best result in my opinion.
Build site:
Gulf birthday cupcakes anyone?
jferraro is offline
Old 07-21-08, 01:34 PM   #4 (permalink)
40bud's Avatar
40bud
7 Tenths
GT40: GTD Finished in
Out of curiosity, can anyone say how much that gearbox weighs. It looks hugh.
40bud is online now
Old 07-22-08, 02:39 AM   #5 (permalink)
mv1313
Sweden
I have problem with the angle of the drive shaft. I cant get the Ford modular motor more forward so i think this is the best angle i can get. What do the knowlege people out there think?
I have not weight the transaxle but i think it is 90Kg = 198 lbs
ID:	31294   Click image for larger version
mv1313 is offline
Old 07-22-08, 02:57 AM   #6 (permalink)
jac mac's Avatar
jac mac
I Have No Life
New Zealand
If you mount the rear upright in its correct position it wont look as bad as your top link & upright is well forward of its correct position in the first photo above. You really need to mockup your rear suspension as accurately as possible in order to measure angles etc and compare them to the limits of the CV's operating range.
Having said that if you can get the motor further forward even 30/40mm by notching the chassis/ cutting down a pulley size/ or removeing a non critical lug or engine part it would help a lot.
With that motor in place its easy to see why the GT was a bigger car than the GT40
Jac Mac
jac mac is offline
Old 07-22-08, 07:03 AM   #7 (permalink)
Scott Calabro's Avatar
Scott Calabro
GT40: TS40 # 875
40 Bud,
I don't know about just the Ricardo, but I have heard the Ford GT drivetrain weighs in at 900 lbs!
S
Scott Calabro is offline
Old 08-09-08, 07:20 AM   #8 (permalink)
mv1313
Sweden
Hello again
Now I have move my engine forward. I modified the steel constuction in front of the engine and take off a little under the transaxle. Now I am satisfied. Iam not finished the steel constuction in front of the engine but I think it`s enought place left for the seat and my self. I dont now why but i cant upload picture. Go too my gallery for more detail picture on my building process.
Picasa Web Albums - Magnus
Thanks for support and help
Magnus Viktorsson
mv1313 is offline
Old 08-12-08, 07:19 AM   #9 (permalink)
jferraro's Avatar
jferraro
GT40: RCR40
Magnus, what type of headlights are those in your car?
Build site:
jferraro is offline
Similar Threads
Ricardo in an RCR gt40fran RCR Forum - RCR40 / RCR70 / P4 / MKIV 16 04-13-08 08:56 AM
Ford GT transaxle tdm434m GT40 Tech - Powertrain/Transaxles 12 12-30-05 05:27 PM
Ricardo transaxles Brian Kissel All GT40 5 11-26-03 07:47 AM
Ricardo visit - p thompson GTD 40 Car Club Forum 3 11-14-03 04:29 AM
Ricardo Transaxle CCX33911 GT40 Tech - Powertrain/Transaxles 7 01-08-03 03:35 PM
