Audi 016 turbo box capacity
Hi all,
I just installed the Audi turbo box that I brought home in my hand luggage.
This box is now in my car and I filled it with oil. It did not take much. Anyone know the capacity of the box?
Think it is the same code as the one I pulled out 016..
Bernie
my box although not the same model came pre filed from audi .They filled it up to the level of the filler plug then after running to fill the oil cooler (mine has a built in oil pump) I topped it up and all seems fine.
Huw
Thanks we filled it to the plug and with the trans up off the ground turned the box over and topped it up. I looked at the box external size and see that we have possibly put plenty in.
The gears rotate in different directions so think we have the right level..
Thanks again
Bernie
