HOward,
I have a set of shifter files that have just about any type of shifter you could ever imagine. Here are the DRB type.The shifter itself.
The interior connection to the rod.
The tail shaft arrangement.
There are variation of this used by many others. Here is one for an Ultima I believe made up by Jhon Evans here in the Atlanta area.
Here is the bell crank, except smaller and closer to the tail shaft.
Here are the dimensions for that particular bell crank setup.
I used this type on my 930, but due to space constraints I approached the bell crank from the bottom of the transmission. I used the Toyota shifter, so I had to use a Z link for the fore and aft movement.
If you are interested in any other type, rod, Brandwood, right hand , center etc. I probably have a pic of it.
